I just made a cross country trip and went over the continental divide.  On my old rig, I had a 10 year old windshield mounted garmin GPS that would display my elevation.
Never thought about it in my new truck until we get into the mountains.   Looked around in the controls and the owners manual and I do not see how to display our elevation in the onboard Nav system.   Am I missing it somewhere, or is it just not an included option?
I’ve never heard of this being an option or standard feature. 90% sure it’s not in your truck, or any GM trucks for that matter.
Never had that option in any of my OEM nav systems, same as speed display like non  OEM units have, doesn't have it on OEM units.
I've had;
09 Tahoe
12 Lexus GX460
17 Audi Q7
17 Audi A4
19 HC
None of which had elevation or speed display. I'm in charge of our company fleet and we has MB S550's, E400's, SL550, Lexus LS500 and the list goes on, not on those vehicles either.
Edited by eppieguy
Typos
Thanks guys, that answers my question!
  • 2 years later...
I know this is an old thread but I just got my truck this weekend and drive through the mountains a bit and like to know the altitude/elevation I am at.  Dissappointing to realize this is not a feature in the built-in nav.  I am trying to find out if it can work through one of the Android Auto apps.  I know there are apps that tell you the elevation.  Both of my Audi's do this - a '15 Q5 and my wife's A5 Convertible and their systems are really archaic.  Maybe someone can chime in if you know the Android system answers as this is very new to me.
Usually, when somebody asks how high they are it's in reference to smoking weed.  Are you guys smoking weed?
Similar story. Sorta.
About 2005 I had a garmin that the screen could be configured to display altitude while displaying route (or just map) info.
The 'replacement' garmin model had altitude info available but it was on a screen buried in the menus and could not be displayed while the map screen(s) were active.
(both were marketed to the same customer group)
Add me to the list of those that would like to be able to have altitude info displayed in a corner somewhere -- but not if it's buried somewhere.
Looking it up on a phone app doesn't cut it for us.
I get that lots live in locations with little elevation change and don't travel much and/or don't care.
But the option to configure the display would be nice.
Edited by redwngr
I think the majority of people this type of information would be marketed to would fall into "don't care" category.  In a single trip I can drive from below sea level (Death Valley) to over 10,000 feet (Rocky Mtn National Park in Colorado), and I'll have highway signage tell me the elevation.
We have done lots of travel across US and Canada.
(48 states, all but one province; many of them multiple times / trips)
Yes, multiple trips to both DV and RMNP.  Etc, etc.
Like many mountain routes, Trail Ridge Road gives a completely different experience in opposite directions, as well as in different seasons.
My my observation has been that the highest passes generally have an elevation sign at the summit -- but many/most intermediate locations do not.
I agree that it's likely that most don't care and/or have no use for such a feature.
But some of us do.
But some of us do.
More food for thought.  Factory navigation seems to be going the way of the dinosaurs and Android Auto and Apple Carplay are taking over.  Those apps also don't give altitude.
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
