So, today I blacked out the GMC emblems on the grille & tailgate on my '19 AT4. My truck is black and I like the sleek black look. This was a simple, subtle mod in that direction.
I used 3M 1080 wrap vinyl & a little heat. They came out nice and if I decide I want them red again, for some reason, I can just remove the vinyl. :)
  • Like 10
That's what we do we have extra vinyl from our vinyl printer and change it up whenever we want with different colors. Makes people laugh when we do green for Saint Patrick's day LOL 10 minutes to put on one minute peel off. Great cheap mod and it looks much better than red, unless it's Valentine's Day :-)
Haven't blacked out the grill yet but debadged all the chrome lettering...  Replacing the AT4 w vinyl .... stand by for pics...
Nice. I did mine too with Carbon fiber. Looks killer when the light hits and makes the silver part of the carbon fiber stand out.
I like it, what finish did you use, gloss, matte, satin?  Thanks.
I used satin. It was just some I had left over from the stripe I did for our Challenger.
I did the same with my black AT4 with the carbon fiber ones. Much better I think. 99a3bf685b4ed8a7202a2c784eccb2ef.jpg927d25b28d91cd68eb8fb198d3f1421f.jpg5b9f5d5433ddbe2cdc7986e02aa10e7d.jpg
Nice job!
Thank you. Black looks a lot better. I agree with you.
HOW DID THE AT4 COME OUT?
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
