4 hours ago, NHAT4 said:
I thought you blacked out the existing 4 on the existing badges.
Nope,  You might have me confused with someone else.  I removed all chrome emblems and installed 2 vinyl graphics on quarter panel
These look good.  I too have a black AT4 but no clue how to work vinyl like this.  I actually like my red but this has got me thinking, heh.
You can do the emblem blackout. Just take the vinyl, cut squares of it that cover the entire letter including the chrome. Lay it on evenly with no bubbles (simple on such a small thing). Take an xacto knife or similar and carefully slide it along the inside edge of the chrome outline. That will leave just enough vinyl after you've got the letter cut out to tuck into the gap between the letter & chrome outline. If it doesn't want to tuck cleanly, use a bit of heat from a heat gun or hairdryer. You could probably even just do it in the sun to make it conform.
If it doesn't turn out, just do it again until you get it right. Vinyl is cheap.
I guess I thought there was more to it than just applying a sticker based vinyl.  I can't imagine it would last very long in the harsh Chicago winter and summer cycles then?
I live in Duluth, MN & we've got the worst weather on the planet, but I just got my truck in June, so I don't know for certain. The 3M 1080 vinyl I used is made for vehicle wraps so it should hold up fine; it has on our Challenger for the last 2 1/2 years, anyhow. I guess I'll find out in the spring how it holds up on the emblems.
A good vinyl will have a guarantee of 10 years, they are made for autos in all climates.
This  is the vinyl I put on my 2013.  Black is so everybody else.
fb235780-bfaa-43ba-a72b-ea688957bd02_zps
  • 5 months later...
Well done, looks great..... WOW... I may have to do this, well not may have to, going to :)
  • 9 months later...
On 11/3/2020 at 11:39 AM, RobbyS said:
Can someone explain to me how to do this? I would love to do this on my silverado.
Order the black vinyl stickers off ebay for like $30.  Then super clean the red part of the letters with alcohol.  Once dry make sure that the letters are not baking in the sun or that its too hot out.  You also dont want it below freezing.  Then slowly and carefully put the vinyl into place over top of the red letters.
    • Okay boys and girls I put a bottle of this in Dizzy the oil burning guineapig after a tank between the coil and plug service of the #3 hole and near the end of the first R&P 5W30 attempt. As a note I did a two R&P oil changes back in October of 2025 with little effect. Granted they were 1K mile a shot oil changes so.... Then followed by fourteen  1K mile changes of Mobil 1 Euro 5W30 FS. Also ineffective.    Anyone who has followed the adventures of Dizzy may remember that to put the oil on the full mark of the published nominal 5 quart change I withhold about a cup of oil. That over the last 50K miles the P0420 light has been a frequent flyer, sometimes three of four a day. And that even on 93 octane fuel she registers some KR even in moderate conditions on favorable days on slight inclines. Lastly when giving her a kick in the pants, something done about once a week, she looks like a diesel with the pump turned up. 😬   After one bottle and over the last 500 miles of a 3K mile OCI, of the first oil change I dropped the nastiest looking oil ever in her history. That's saying something as  you will recall I have used AutoRx, HP EC30/40 and a few other harsh solvents in her before including the GM top soak twice. This was syrup. Black stinky, inky syrup but the filter wasn't all that bad.    On the second fill I had to use the entire 5 quarts to reach the full mark. That was unexpected! The ignition KR is completely gone! Even at 99% engine load. MAP is much lower. Level road is now 9.8 instead of 12.5. Fuel economy is remarkably higher and for the first time since her earliest days she will spin to 6500, more than a thousand higher with out laying down dead. Yes, the coil and plug had something to do with that but remember the first 2500 miles after that repair on the first change it was same ole same ole Dizzy. Seems we have top rings that are somewhat functional again. P0420 code only comes on now if run in town for more than an hour of stop and go. On the open road it goes weeks without a incident. Perhaps it is cleaning the cat on the pass through?  Fuel Trims have improved as well. Nothing not to like.    To early to say about oil economy but the changes to date in the operational aspect is remarkable. I can't think of a worse case than Dizzy.... It's already paid for itself in a few tanks of fuel with the mpg improvement.    @OnTheReel, I'd say if the Jeep didn't respond perhaps there wasn't an issue to respond to.    I've run the Red Line SI-1, AMSOIL fuel cleaner, GUMOUT and Techron all in this SUV without any such results. Color me impressed. I'll be running out my supplies of the list mentioned and moving on to the Valvoline R&P Fuel System Cleaner.
    • Hey Chuck !!Thanks for the all the info I'm an old fart and I have everything I need for the oil change at home,minus flexibility .... and I’ve been doing my own oil changes for 40 years. I just didn’t want to end up without a crush washer or with the wrong one in my stash and have to walk to the auto parts store, lol. I climbed under the truck to check the location, and man, it’s going to be the easiest oil change and filter swap in the last 40 years—right up there with my 2014 Mitsubishi Outlander 2.4. No mess, nothing to drip on—just perfect. I’ve got one more free oil change to use, and then that’s it with the dealership!
    • I think this subforum was created for the new generation pickup trucks (2027-) with the 3.0 but I don't think it's a big deal either way. There are probably 2027 model-year specific changes for the SUV's too.   I was just curious if you had issues with your 2025 3.0. I'm still under 10k miles on mine and fingers crossed I don't have thrust bearing issues. I'm guessing not, since you're willing to buy another one! It's a good engine minus one or two manufacturing whoopsies.
    • Wife has enough metal in her she hides from the scrapper.
    • Djannoyed was a one hit wonder. Posted and disappeared.
