So, today I blacked out the GMC emblems on the grille & tailgate on my '19 AT4. My truck is black and I like the sleek black look. This was a simple, subtle mod in that direction.
I used 3M 1080 wrap vinyl & a little heat. They came out nice and if I decide I want them red again, for some reason, I can just remove the vinyl. :)
  • Like 10
That's what we do we have extra vinyl from our vinyl printer and change it up whenever we want with different colors. Makes people laugh when we do green for Saint Patrick's day LOL 10 minutes to put on one minute peel off. Great cheap mod and it looks much better than red, unless it's Valentine's Day :-)
Haven't blacked out the grill yet but debadged all the chrome lettering...  Replacing the AT4 w vinyl .... stand by for pics...
Nice. I did mine too with Carbon fiber. Looks killer when the light hits and makes the silver part of the carbon fiber stand out.
I like it, what finish did you use, gloss, matte, satin?  Thanks.
I used satin. It was just some I had left over from the stripe I did for our Challenger.
I did the same with my black AT4 with the carbon fiber ones. Much better I think. 99a3bf685b4ed8a7202a2c784eccb2ef.jpg927d25b28d91cd68eb8fb198d3f1421f.jpg5b9f5d5433ddbe2cdc7986e02aa10e7d.jpg
Nice job!
Thank you. Black looks a lot better. I agree with you.
HOW DID THE AT4 COME OUT?
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,225 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
