I have a 2021 Silverado LT with the same issue. Fog lights installed and working properly. Dash indicator is not working. Dealer spent 2 hours on line with TCSC and no luck getting the dash indicator to work. All wiring is double checked and correct. No jumper from BCM was required because factory installed one provided continuity with UEC body 2 connector C3 factory installed terminal.
If anybody knows the solution or a dealer who knows the solution please let me know so I can resolve this fog light issue of the dash indicator light failing to illuminate.
Well after fully installing the entire GM fog lamp kit,  (aside from the brown jumper cable because there was a pre-existing one) the truck has no power whatsoever. Anybody come across this issue? There’s literally nothing that turns on and not even a jump start helps.
Rami2096 it sounds like you might have a connection problem with your BDM connector (x5 Brown) under the dash. I would recheck that it is fully engaged and completely secured in the mount.
I have a 2021 Silverado LT with dealer installed GM fog lamps. My dealer was unable to get the dash indicator to work either. I purchased a small green led lamp from Amazon. I ran a wire from the left side fog lamp hot wire to the LED( I installed in the lower panel, left of the steering wheel) and another wire to ground. Now I have an indicator lamp. My GM fog lamps are not all that powerful. Diode Dynamics tells me that they will have an installation kit available by the end of the year for their excellent SAE fog lamps. This kit will fit 2019-2021 Silverado's.
DGstarr63 Agreed they are not all that bright. Thanks for the info.  If you could post a photo of your installed indicator light I would appreciate. Sounds like the best option.
Edited by Carm58
Updated request of dgstarr63
So it is now 2023 and I just had my factory fog lights installed by the dealer in my 2020 Custom. The lights are turning on, but like many have stated, no indicator light on the dash. I guess it's back to the dealer.
  • 2 years later...
I have a 2021 Silverado Custom Trail Boss and I purchased an OEM-style fog light kit from Phastek. As I started going through the install, I noticed that BCM connector X5 cavity 10 is already populated from the factory with a blue wire that has a brown stripe. According to the kit instructions, if X5 cavity 10 is empty you install a jumper wire from BCM X5 cavity 10 to UEC connector C3. In my case, there is already a factory wire in X5 cavity 10, but UEC C3 is empty, and the kit does not include any other wire that populates C3 besides the jumper. UEC B3 is also empty. The headlight switch with the fog button has not been installed yet and the BCM has not been programmed yet. My question is how the BCM communicates the fog lamp command to the UEC once fog lamps are enabled in programming if C3 remains empty. Will the BCM drive C3 internally after programming even without a physical wire present, or is the expectation that the factory wire in X5 cavity 10 should be removed and replaced with the jumper wire to C3 so the BCM can signal the UEC. I am trying to understand the correct architecture before depinning anything to avoid backfeeding or unintended lighting behavior.
    • I certainly could be wrong but I hear of pickups far newer than that 2007 cutoff which may not be going to the wrecker but are having engine work done and be that a reman engine or new engine or trying to repair the existing engine. Some of it would be design issues as per the cylinder deactivation system that GM has and one of those lifters wiping out the cam and the question of oil changes moving the needle or not on that whole mess, or in the case of Ford pickup engines that have the long timing chains and wearing them out and the roller followers and phasers and some of that certainly goes back to oil change intervals. But in those various cases the truck has all sorts of life left in it and so the unfortunate owner and may be original owner or used market owner that is pouring money into repairs so the truck is not seeing the salvage yard yet but damage is happening by infrequent oil changes. A friends son had bought a 2018 I think it is half ton GM and it had some sort of extended or used dealer warranty on it and of course the lifter issue bites and its rattling and so the dealer had to swallow the bill and was at least 7000.00 and I think they only replaced what they felt they had to replace so yeah, I can see that being a ticking time bomb in the not too distant future. Would frequent oil changes cure all these engineering "marvels", probably not but some engine designs have shown that they do much better if the oil is changed a lot more often then if the manufacturer service claims are followed. New trucks cost so much that there is an incentive to keep the existing truck on the road by repairing.
    • get a good code reader, and find out what problems the truck has noticed by reading codes. cheap ones can only get basic engine codes, you may want to get one that can get codes from all the computers in your truck.
    • This is sort of my point, salvage yards aren't overflowing with all these 'poorly' maintained trucks - excellent/good/servicable condition otherwise, salvaged only as a result of a bad engine from poor oil change regiment.    In my area, there are no 2007 to newer gm trucks/suvs in any salvage yards. A few are in the 'recyclers' with very obvious reasons for being there - wrecked.
    • Stabilitrack was a stability control, traction control system, that functioned independently from the transfer case.   Z-71 has nothing to do with the transfer case or differential.   If it does have an AWD system, my memory recalls this being specific to the Denali trim, converting won't be as simple as swapping out mechanical parts like differentials and transfer cases. It will require reprogramming at a minimum. Long story short, not likely worth it.   Pulling a fuse, may disable the AWD system, it might also prevent any other transfer case functions.   However, the AWD case was generally based on the same transfer case you refer to in the 2006 Suburban. If it still has a 4-High and 4-Low where the transfer case locks and splits power 50-50 front to rear, what are you gaining by changing anything? A true-rear wheel drive only, what good will that serve? Not enough to go through the trouble of changing out all the parts.    Generally, all the factory systems will handle a 33" tire and re-gearing. Probably a 35" tire too, if you aren't driving like a caveman. If 35" tires are in the plan...   If you do plan on driving like a caveman or are fully committed to 35" tires, an entire re-think of the build is probably in order. Starting with square one, an IFS front end isn't going to be the best starting point for 35's and caveman driving.
    • 1/2 qt over full ain`t gonna hurt $h!t. Most times, a whole qt won`t either. Most have windage trays now. As long as the crank isn`t slapping itself in the oil, it`s not the end of the world.   We used to overfill 1 qt at the track, at race time. Better to have it over full than having the pan sucked dry at 6500 rpm`s.
