Dealership spent about 3 hours and could not figure out how to get the LED fog light kit to work. I have double checked all the wires except for in the fuse box.
They did program the BCM as the dash lights up with a fog light icon now. I can only conclude that they installed the BCM wire and fog light wire incorrectly into the fuse box.
Has anyone completed this installation that could provide photos to verify the location? They are wanting to keep my truck overnight and give me a loaner for fog lights :dunno:
Thank you.
I've got everything done on mine but connecting the wires to the 2 fuse boxes. The instructions are confusing to me and not very clear.
I guess I'll have the dealer connect the wires when they program it.
I spoke with the shopchevyparts where I purchased the kit. They told me that many dealers are making the mistake of programing the BCM the old way instead of calling a specific number and giving them the VIN and code included in the kit. Hoping that was is the issue. I will be going back next week.  Hope you have better luck.
Edited by TBHiker
45 minutes ago, TBHiker said:
I spoke with the shopchevyparts where I purchased the kit. They told me that many dealers are making the mistake of programing the BCM the old way instead of calling a specific number and giving them the VIN and code included in the kit. Hoping that was is the issue. I will be going back next Wed.  Hope you have better luck.
I had a similar experience when trying to get the bed cargo lights activated on my truck.  Local dealer asked me for the activation code and there was none in the box.  TCSC (internal GM department providing the updated BCM code) won't activate the lights without it.  Ended up returning the kit and ordering another one from a different dealer on Ebay (both were about $30 cheaper than my local dealer including shipping).
This one also came without an activation code.  This time the selling dealer told me that TCSC will supply the code.  I called TCSC myself to confirm (Ebay dealer gave me the phone number).  Apparently there were 265 kits produced without codes in the box and they are supposed to honor it without the code.  Just my luck I ended up with 2 out of 265.
Good luck.
I installed my own then had them flashed w the authorization code. Only problem I have is that the indicator light doesn’t come on w the fogs. I’m assuming it’s bc I did not do the jumper wire from under the dash to the outside fuse box. Anyone else have this problem. Lights work like they’re supposed to.
I have the same problem.  During install, it mentions if there is a wire on the bcm connector on circuit 10, then there is no need for the jumper.  I went to the dealer twice now, first time for the initial program and this time for them to verify the programming.  The tech line doesn’t know why the dash icon doesn’t light up.  I’ll be verifying the pre-existing wire on the bcm connector and under the hood for continuity tonight.
At at least the lights work though.
I noticed a connector in mine.
The one under the hood had me all kinds of confused. Like do I run the wire up underneath? Plus what I had taken apart, didn't look like the diagram. :(
In the attached pictures, the small brown connector is what is in the BCM under the dash.  Mine already had a brown/white wire so the instructions said I didn’t need the jumper.  In the other pictures, the green connector is what you open and the wire gets installed from underneath.  I had to remove a wire from B3 position to be able to install the wire from the kit.  I did not have to remove the wire from C3 since that is the brown/white wire already installed.
Also I just tested the pre-installed brown/white wire and I have continuity.  So I do not need the single jumper wire provided in the kit.
Edited by sse1990
Okay...so I was correct. I just couldn't pull it up enough to see underneath to see where the wire needed to go. I couldn't tell from the top either.
The green base can come up also which will give you more room to separate it and have more room to work. I think there are 2 tabs holding the base down.
10 minutes ago, 316hepster said:
Does the fog light indicator light up when your fogs are on?
Mine doesn’t and the dealer doesn’t know why.  They called the tech line and still no answer.
My fog fog lights work.  The dash indicator does not.  The tech line figures it wasn’t installed properly.  The jumper (brown/white wire) from the brown BCM connector to the green connector under the hood was already factory installed and I only had to install the one wire that was part of the harness going to the lights and goes to a second location in the green connector.  I’ve tested the brown/white wire for continuity and it is the correct wire and tested good.  Also when you turn the fog lights on, the brown/white wire on the BCM connector sends a negative signal which is what turns the fog lights on.  That tells me it’s installed correctly and it is not programmed correctly.  I may talk to the owner of the dealership and see if I can go program it myself cause it doesn’t look like they know how.
Cool. Same situation here. They tried to tell me I didn’t install it right and wanted to charge me after they did the flash to further diagnose the problem. At first they told me that’s the way it’s supposed to function. I was like “No...”. ?
When I had mine installed at first the light on the cluster didn’t turn on and then after they flashed the bcm the light worked every time the fog lights where turned on
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
    • So after reading the reveal from Chevrolet, I kept asking myself...why did the trim levels change?   Here are the official ones:   Work Truck (WT): The quintessential fleet truck, built with durable, easy-to-clean interiors for commercial or utilitarian use. Custom: A stylish, road-oriented trim that adds a more refined appearance, standard dual exhaust, and modern exterior styling. Custom Trail Boss: An entry-level off-roader featuring a 2-inch factory suspension lift and 34-inch mud-terrain tires on a budget. Silverado: Serving as the new base consumer truck (replacing the previous LT trim), it comes standard with the Z71 off-road package when equipped with 4WD. Trail Boss: Steps up the off-road hardware with the 2-inch lift, 34-inch tires, monotube shocks, an exclusive off-road hood, and more premium interior options. ZR2: The flagship off-roader. It boasts 35-inch mud-terrain tires, Multimatic DSSV dampers, front and rear electronic lockers, forged carbon-fiber interior accents, and an available hardcore Bison Edition (co-developed with AEV). High Country: The pinnacle of luxury. It replaces bright chrome with modern satin chrome, 22-inch wheels, premium leather, real wood interior trim, a panoramic sunroof, and an exclusive front-passenger touchscreen. As others have stated, why would you want a Silverado - 'Silverado' - wth?? LT needs to remain!!!   Also, there will no longer be a dedicated Z71 model.  All 4x4 trucks will have the Z71 package. Carplay is also something that cannot be removed.  Hopefully it will remain.     I am excited about the 5.7L V8 (350 C.I.D.)  Old school Chevy power.  My only concern is whatever version of AFM/DFM cylinder deactivation.  Too bad that isn't an option a buyer can choose to have or not.   I will definitely be stopping by my local dealership when these trucks start showing up.
    • I haven't seen diesel for less than $5.30 anywhere in my area
    • The not as clean as one would assume theme with the new engine oil, that reminds me of comments over the years with mechanics not always being so on board with filling an oil filter, not from the center anyway due to that typically being the clean side of the filter, danger of some contaminant falling into the filter if not careful but the realization now that the oil may not be as pure as one had assumed it would surely be. Yes it would be possible to fill from the small holes but that means messing with something to prop open the anti drain back valve if the filter is so equipped and not damage that valve in the process. Me, I have hardly ever prefilled an engine oil filter however I have prefilled diesel fuel filters with a filter on a fuel bulk tank and for anyone that has messed with diesel engines with filters and units that have a limited or no way of priming them, putting on a dry filter is a bad day to say the least with those crappy systems. But anyway back to not so clean engine oil, indeed perhaps its not so bad after all that I have not made a practice of prefilling oil filters.    As Grumpy Bear commented on keeping things clean, that I really have to wonder what the typical practice is at a dealer or any other shop that changes engine oil, do they make sure to wipe or wash off the oil plug and certainly if it fell into some gunk or onto a dirty floor, or that they wiped the filter mounting flange and didn't go and use some dirty rag and end up adding dirt to the inside of the head of the filter mount. Or be careless in how they stored or handled the new filter and if they were bumping into items under the vehicle with the filter opening facing up and having dirt drop right into the filter and if so right into the threaded center that is on the clean side. The top side, did they clean away the built up gunk that may be around the filler before removing the cap or to be really careful at that point that something right close to the filler hole that was hidden under the caps flange won't fall into the engine. Or did they clean the funnel or was that just laying there covered in oil from the oil change before and dust kicked up from sweeping the floor stuck to the oil and now that will go running into the next persons engine due to just not cleaning the funnel as "they won't know anyway" attitude as that young guy is more worried about taking a break so he can go outside and smoke a joint. Just random points that came to mind when I think about what some hired personnel may do that the shop foreman has no idea of or perhaps the whole attitude of some shops may be "eh ... who cares, they will never know the difference anyway".
    • $3.69 for 87 octane.   $4.24 for Diesel in town.
