Transmission gauge
It should be in the drivers information center in the cluster.
If you don't see it listed you should go the options menu I believe and you should be able to add it.
If you have the digital gauge it shows up when you put it in tow haul mode on furthest right gauge
Otherwise it is in the options when you scroll through (baring you have it selected)
A 3500 is a heavy duty truck meant to work and trans temp is important.
A 1500 is a light duty truck and 99% of the time won't be worked hard enough the trans temp will ever matter.
