ac not working
First I want to say Hi to everyone new to forum. The problem I am having ac blowing hot air , checked fuses and relays all good, ac clutch is working checked lowside pressure reading is 28 lbs when clutch engaged . The truck is 2014 sierra 1500
I welcome all help .
 Thanks leadfoot
28psi is low for how warm it is in the summer. Should be well up around 45-55psi.
Sounds like the system is might be low on R134a. And if that is the case, you have a leak.
  • 3 weeks later...
 Thanks leadfoot
check the charge on the system if it is low, you have a leak. 9 out of 10 times its the condensor
On 7/30/2019 at 5:41 PM, Frankielozano214 said:
My truck just started blowing hot/warm air today, use to b an ice box!!! Smh any luck on your truck?
Change the condenser and vacuum and recharged the system
