Transmission
Jdm5630
I have a 2015 silverado that just turned 100k miles. Transmission fluid has never been changed. I'm looking for opinions on whether or not to change it. Any ideas? Any advice is helpful.
Yes, change out the filter and fluid.  It isn't hard to do.  You can find how on Youtube.
Here is a write-up I did on my 2002.
No "flush".
If you want to go more in depth you can add the new fluid and let it run a bit to mix in, then pop a trans cooler line off and run the fluid into a bucket/empty jug. I wait till I get about 3-4 quarts out, hook everything back up and top it back of with the same amount of fluid I pumped out.
I do that to get a roughly 8-9 new quarts added/mixed in.
Take it to a good shop and have it flushed.  It will NOT damage the transmission and it will be MUCH more efficient than a drain and fill.
There is no way to completely empty the thing. All methods rely on pumping out a few quarts at a time, mixing it back it with new stuff, and then repeat.
I think I’m going to take mine somewhere to get a full flush, when the time comes.
You can do a full fluid exchange by disconnecting the return line from the cooler and putting a tube on the end of that and into a bucket. Then start the truck up and let the transmission pump out the fluid into the bucket. When you see it start to slow down and get air in it, shut off the truck, add 4 more qts to the transmission and repeat.  It will take 16qts to completely exchange the old fluid to new fluid.
The only thing that makes it harder on the 2014 models and up is that there is a thermostat on the transmission fluid lines on the side of the transmission and so no fluid will flow through the cooler until it is hot enough for the thermostat to open.  There are several Youtube video's showing how to by-pass the thermostat.  You want to have the fluid run through the cooler so that you exchange all the fluid out of the system and not leave any of the old fluid in the cooler.  The thermostat makes it a little harder to accomplish but it can be done.
this will be the safest and most efficient method, go for it.  Just make sure they use good quality ATF rated for that tranny.  You won't be sorry.
