Who knows where to get the colored inserts for the “Chevrolet” grill? Adding red accents on my all black 2019 and saw one guy with them and he won’t respond to anyone where he got them....
Two I saw were custom made . I talked to one guy who did this and he told me he got red vinyl and took the center grill out and wrapped behind it .
The other one one I saw painted a thin piece of metal and took the Center grill out put behind it .
Ive seen it in red and orange.  It does look good.
You prob could get a local body shop to customize it for you or wait few months and probably one of these companies will
start making a insert .
Edited by boneill
Like the user above me said. I used a vinyl wrap. Very easy to do.  Take your grill off and then that the center piece off the grill. Once that was off I just laid wrap on the little platform and it shows up through the letters.  Had red. But now switched to color match truck
Did mine today and it turned out awesome. Thanks for the advice!
4 hours ago, mbehm3 said:
I like the bow tie under the “Chevrolet” on your grill! Where’d you get that??
I plasti-dipped mine. Pulled it off, turned it black, then covered the black to paint the chrome outline. You can also buy a black one and change the chrome outline.
So it turns out vinyl for this application may not be the best. Idk if it’s the Arizona heat or if it was the big rain drops. I have holes everywhere in the vinyl because it doesn’t have a flat background, it’s on a grid pattern. Time for me to think up a new way to do this, because I really like the red look.
  • 5 months later...
I'm interested in doing something similar. Did you ever find a fix for the holes in the vinyl? I'm also curious as to if there is enough room for a thin piece of plastic to be wrapped and put in place. I haven't taken mine apart yet to look.
give this topic a look, I have my aluminum flashing ready to go for this weekend...
Thanks for the link. I'm definitely gonna try this!
  • 7 months later...
I jus put a layer of PPF over the red vinyl, never had n is sure with holes whatsoever, and I use pressure washer a couple inches away from it to get bugs n debris off, and it’s lasted our -40 c winters where I am so far.
    • I see where you’re going and I can appreciate that. Statistics can be misleading because of the word average. They say statistics show the average cost of a new vehicle is about 50k. The average monthly payment is close to 1000 dollars a month. That’s statistics for you. I know very few people who pay that.
    • same here , i have a 2020 first gen and the cost to repair these engines far excedes replacement
    • But Grumpy I did show several subdivisions that had homes starting in the 170K range. If you bought a Townhouse or Condo you could go cheaper. Same with a car 3000 dollars in the 70s translates to around 20K today. There are several models at that price. You actually get more for the money. In the 70s I drove a 3000$ car bought a 28K home and made 4.50 per hour. Thank goodness for overtime. Today I could buy a 170K house drive a 20K car and make 25 dollars an hour operating the same machine today. The difference the house, car, machine would be better and have AC. And I wouldn’t be taxed on overtime. And statistically your wife works too. Easing the burden. I thought we agreed to disagree. I brought receipts earlier, showing examples. I think you’re more stubborn than me. I was done with this debate.
