Dealer says shaking Yukon Denali is normal
mwmx54
Occasionally I tow a boat or small trailer with dirt bikes in the wife’s 2015 denali XL, and on slight up hills around 70 when it downshifts usually it will get to shaking, which goes away instantly if I floor it, or let off, I have replaced all 4 wheels and tires on the truck, had them road force balanced, balanced boat trailer tires, replaced boat trailer tires, just to cover my bases, even though it’s a slower shake than what I think an unbalanced tire feels like.  the Yukon is still under Powertrain warranty, at 60k miles, the 5 years are up soon though. I finally decided it’s not a wheel tire issue and took it in to the stealership to diagnose. They had me bring the boat since that is when she gets to shakin the most. They say they felt the shaking and said it’s normal. Boat weighs in at 4000 lbs FYI. This isn’t just engine vibes, it a real shake felt through the entire car almost like it’s trying to shift up or down really fast, or dare I say, a clutch is slipping. ATF was flushed about 5k miles ago, however this issue has been going on for the last 10k miles at least. I rarely drive it, so I never really knew what was up other than maybe the tires could be unbalanced. I argued with the service manager about why such an expensive (luxury)vehicle would shake when towing less than half its capacity, and asked him to show me a different Yukon that does the same and he said he tried, but was told he couldn’t. My bro pulled the boat behind his 2012 Tahoe and felt no shaking, nor do I when towing behind my 1997 or my 2017 power strokes. I am worried something bad will happen(outside of warranty) if I don’t get it figured out, however the dealership seems very unwilling to do anything for me, especially knowing it’s almost out of warranty.
Either trade it now or get an extended warranty immediately. Does this have the 8 speed M5U transmission in it? What your describing sounds like a transmission issue, or TCC shudder. They can road test it with GDS 2 installed and command TCC on 100% and off 100 % and if the shake goes away than you have a TCC problem.The converter never locks up 100% in normal use and is always slipping, piss poor design that will fail eventually. On 7/29/19 they issued a TSB for the 2019 trucks with 8 speed for TCC shudder. They can't get anything right. Get a 10 speed and your problems are solved.
I would try another dealer see what they come up with. As far as trade it in now. For me that would depend on how much you like it otherwise. The hit you take on trade in plus buying another depreciation asset would weigh heavy on my decision. After all the transmission cost is nothing compared to those cost.
We do like the car, and I don’t think the 2015’s had the 8 speed yet, but I’m sure either way it would be a spendy transmission to rebuild. I bought a 2015 cause they had 100k mike warranties, that I’ve never even used by the way, but I feel like they’re sending me on my way knowing that the car only has to make it a couple months and warranty is up, and if it is the tourque converter, it can take the rest of the tranny with it right? I guess another question would be, has GM recognized this problem and released any sort of bulletin or something saying it’s normal, or what can be done to fix it?
8 speeds came out  in 2014. Send me the last 8 of the vin and I will look it up for you if you like.
That would be cool, any chance you can see the build date as well? Actually I need the sale date to determine exactly when the warranty is up. Here is the last 8 of the vin
fr214537
Thanks
You have  the 6.2 engine with the 6 speed MYC transmission.The build date was 6/20/14.The delivery date was 8/29/14. Power train expires on 8/29/19. Make sure you get your complaint in writing with the date and mileage listed correctly on the repair order as you have been complaining about this issue before the warranty expired.Being that it is the 6 speed the most common failure I see with them is torque converter failing and taking the pump out from metal debris and also the 4-5-6 clutch plates burning up with heavy use.Good luck.
Thanks that’s good info to know. I appreciate your taking the time to look that up.
Does anyone think it would make a difference to try a different gmc dealership to see if they come up with something else? Would it be better to tell them I already took it to a different dealer and got turned away? I’ve never dealt with warranty issues, let alone hiring a shop to do the work for me, I went to automotive mechanic school and was a mechanic for a several years long ago, so I’ve always done the work myself, not that trannys scare me, but this is kind of an expensive vehicle that should be covered, a big factor in the purchase was the 100k mike Powertrain warranty, and now they aren’t honoring it.
Edit: maybe I’ll take it in to the 2nd dealer and not mention the warranty, to see what they come up with, hopefully without looking too much into if it’s still under warranty.
The first thing the dealer does is put in your VIN and run the history on the vehicle. You don't have to say a word and they know everything about that vehicle. Where it was bought and made and any open campaigns.Any warranty work done any where shows up as well.Try another dealer and see what happens, what have you got to lose? Sucks your regular dealer won't take the time to diagnose and fix it.
Every visit to the dealer gets entered into the system.  They know where, what and when the vehicle was in the service dept., not just warranty work.
You answered your warranty question with your title. They’re saying there’s nothing wrong with it. So taking it to another dealer would be my next option.
Be persistent and polite.  There is nothing wrong with getting a "second" opinion but I suspect the two dealerships will support each other.  Phone GM customer support and see if they can't further your case.  Over the years, I've made several warranty claims on various vehicles and it is not unusual for the first visit to get an "it's normal " diagnosis.  It's like visiting my Doctor.  He usually says, "give it two weeks" and if it still bothers you...
Get it in as soon as you can.
The torque converter just failed in our 16 LTZ Tahoe at 62000 miles, just out of warranty, but my wife did report the issue before it had expired, so on go the boxing gloves for a fight about who is at fault.
When she took it in for the vibration issue, they found the rear Magnaride shocks were bad, and replaced both for $1700.00, now the TCC is bad, thinking they never bothered to check the TCC like they were asked to do.
And to make this even more fun for "Hip National Bank", the steering rack has been deemed bad and needs to be replaced right away.
That sounds like the beginning of a nightmare, I’m sorry to hear that.
Does anyone know if any service bulletins or anything relating to this issue? Something that I could take to the dealer to point them in the right direction?
At this point don't even worry about the TSB's.
Request a ride along with a tech, they have the ability to shut down the torque converter while the truck is being driven.
Basically, if they shut it down and the vibration goes away, and then turn it back on and vibration returns they can pin it down to the TCC.
Make sure that what you are asking is being documented in your trucks file, and if you need too, call GM customer service and open a claim/complaint just so you have some recourse when your warranty expires.
    CaptainDad
    CaptainDad
  • Who's Online   7 Members, 0 Anonymous, 566 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
