Highest Mileage 19’s
Thank you everyone for the feedback on the prior post on whether to switch to a 19’ or not.
Another quick question for everyone. Who has more than 15-20k miles on their 19’ already? I bought my 18’ in December and already have 17,000 and change on it. Another 200 going on the clock today...
  • 1 month later...
Just rolled 10k since June.
1.   Need to have a rotational squeak fixed in the front end.
2.  Fixed the headrest rattle myself.
I picked mine up 10/18/18 and I have 20,500 miles on HC 6.2. No issues at all.
5 minutes ago, pschne1 said:
Trail Boss Lt. picked up in January. 19k. No issues until last week when oil cooler line failed.
Damn! I've seen a few of those on here.
What's your build date?
Did you require a new engine?
Build date of 12/18. Everything seems fine after repair.  I got off the road quickly and shut off within 2-3 minutes of getting the low oil pressure warning. Dealer got warranty extended on the engine.
Crazy man. Did they happen to say if these lines failing was a bad batch or something?
I've done some research, and no one seems to have any info on those lines failing and if they were just a bad batch on certain build dates or what
The dealer had never seen it before, or so they said. I emailed them the link to the posts on this site.
Picked mine up 11/17/18 and have 56,000 so far. Only issue thus far was a leaking back window.
Whew that's a lot of driving! 5.3 or 6.2 ?
It’s a 5.3. I drive about 90% highway. I’ve gotten 20.3 mpg for a lifetime average.
Do you know where your truck was made?
Sorry for changing topics, mine has 10486 miles(not even close to some people on here).
    CaptainDad
    CaptainDad
  • Who's Online   5 Members, 0 Anonymous, 487 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
