My 21 Silverado 1500 sounds like a someone blowing over an empty pop bottle at 70+ with a strong crosswind.  Upper passenger side windshield is where it appears to be coming from.
 I thought maybe it was my new windshield.  This post has me thinking otherwise.  Anybody have a fix yet?
I have the same howling noise as well.  Only happens on strong windy days and I swear, I can literally feel the truck move a little likes it’s taking in wind when it happens.  Been waiting for a call back from my dealer for 3 weeks now with new door to Body seals.
I have a 2020 silverado, trailboss, and I have the same issue.  When driving into a crosswind, door or window whistles.  If it is a real windy day, it whistles so loud that I can barely hear the radio.  It is worse on the passenger side, but driver side will do it as well.  Dealership tried adjusting the passenger door twice, and it hasn't helped any.
Does anyone have any updates/fixes to this issue?
I had maybe the same issue.  I took a video of it and sent it to the service guys. It sounded like a clarinet playing a single, really bad note.  Loud enough that it was hard to talk over.  Started with a strong head wind on the highway.  The lowest speed that it would make the noise was abt 65, but more often than not closer to 80.  One of the techs said that he know someone that had seen it before.  They found it.  It was the passenger side weather-strip that cause it.  They ordered new and replaced it.  We had 30 mph north wind they day they replaced it.  The tech could not reproduce the issue after replacing the weather-stripping.
I hadn't heard it again after that one time. Still hadn't brought it to the dealership.  Truck is 4 months old and only 2300 miles including a 1000 mile trip to buy it. I will update once I have the energy to bring it in.
  • 4 months later...
was it the weather strip around the door or window?
I just got back from a 500 mile trip out of town and experienced the same howling on the driver's side of my 2021 AT4.  Anyone know which weather stripping the dealers are changing out to alleviate this?
Thanks
  • 4 months later...
Been having this same loud whistling issue at highway speeds with my 2021 6.2 liter AT4. However I seem to notice that when I hear this whistle as soon as I crack my window the whistling stops. Any ideas?
Edited by jrollie
Similar problem (2020 1500 RST), passenger side approximately below air vent in dash or adjacent spot on door.  Starts at about 45 mph.  Mine is more like a rattle/vibration that increases with speed.  Some crosswinds will nearly make it go away for a bit.
On 3/16/2021 at 2:28 PM, Philbert said:
Thanks for the update. Was it a rattle noise or a loud howling? I have an AT4 6.2 with 1500 miles on it and for the first time over the weekend heard this very loud howling noise that came and went when I was driving about 75 mph in strong crosswind.  So loud my wife and I went WTF.
I have a very loud howling on mine as well, but sounds like its coming near my left ear.  Was your sounds that high up on the door frame?  Mine is at 70 plus and cross winds as well. Just want to get this fixed asap. Any additional help is greatly appreciated.
Same issue here. Did you ever find a solution? It’s driving me nuts!
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
