Just ordered sub.. Should I DSP or LOC?
Zipsort
I just ordered
https://www.sonicelectronix.com/item_142893_JL-Audio-Stealthbox-SB-GM-3GSLVCNSL-10TW1.html
and to power it
https://www.sonicelectronix.com/item_97403_JL-Audio-XD300-1v2.html
I have a 2015 without bose.  For now, I'm just looking to add the sub.  In the future I might mess with the speakers.
Anyway my question is, is it necessary to spend the money on a DSP?  Such as the axxess, fosgate one I've seen talked about on here.. it seems most people do that just because of the chime issue (which shouldnt be a problem as a subwoofer) or can I get away with just tapping into the speaker lines for a high output line?
I used an Audiocontrol LC2i tapped into my speakers to run my sub. Everything else is factory. Works great.
My amp already has high level input, though.. so I should in theory be able to run the speaker wire directly to that without the Audiocontrol is what Im thinking.
Ah, yeah it looks like your amp has decent low pass filtering, so you can give that a shot. Mine is an older one that doesn't have that.
Let us know how this turns out. I to have that weak non bose and tried tapping into the rear speakers without a dsp. Sucked. A sub and amp that would normally make the cab vibrate massively had less out put then your current amp. Looking into the jl 360 i believe it is or something to keep the bass line flat and boost the signal to atleast 3/4th the volume.
Hmm, did you use a LOC or just hook up straight to the amps high input?  Maybe I should just use a dsp
From the rear doors to the amps high input.
Sent from my LG-G710 using Tapatalk
Welp looks like Ill be buying a DSP then
2 hours ago, Maxsuperdog said:
Jlaudio
XD-CLRAIC2-SW
I would use these and get the remote bass knob for that amp.
Yeah this is what I was going to do, but it seems people are recommending to go with DSP.  If I'm already spending 1k plus on this setup I might as well just not cheap out on this part.
7 minutes ago, Maxsuperdog said:
If you're only adding a sub it is pointless to add a dsp.
What do you suggest? The signal needs to be boosted and cleaned up
LC2i LOC tapped into your rear speakers. That's what I'm running and it sounds fantastic.
Thats what I'm talking about. Right on Thanks!
    rayredbone
    rayredbone
  • Who's Online   5 Members, 0 Anonymous, 435 Guests (See full list)
