On 4/12/2021 at 1:36 PM, Steven Smiley said:
Just installed the Cognito kit with UCA and Fox Shocks. I am measuring around 42 Inches all around from the ground to the fender opening. Is that what you all are experiencing? I have the same wheel and tire setup coming as firstascent. I wasn't sure if I should bring up the front a bit as I do have helper bags going in to help with my 5th wheel. I want to make sure I have clearance for the wheels and tires.
Just installed the RC 3+1 kit set at 2.5" in front. Replaced the rear block with a 2" block and running 295/65R20. Truck sits 42.5" floor to fender in the front and 44" floor to fender in the back. Rides better than stock IMO. No regrets and would recommend to anyone. Just have to make up my mind on wheels now...that's where I'm struggling.
10 minutes ago, KTDanforth said:
Do you have some side profile pictures?
Not sure if your asking me or not but here is mine with stock wheels and 295's
Looks Good, nice and flush
It's close, hard to get a proper pic of it. It is still tucked in maybe 1/2 to 5/8"
