On 5/25/2021 at 2:11 AM, davester said:
I know this sounds crazy, but why not just install an inverter powerful enough to run whatever equipment you want and be done with it?  It's not super difficult, and you get what you need.
Why would Chevy advertise it being able to work with certain power tools or power up a whole house when it can't? I just saw a commercial showing the Silverado being able to. Total crap.
Perhaps you misunderstood what was happening, or missed the fine print on the screen at the time?  While it can power some power tools, they wouldn't represent the current silverado as being able to power a house.  Perhaps you saw something related to a future electric silverado?
Can you post a link to this advertisement?  Chevy likely has their ads on youtube...
Starting at 9 seconds. This is almost what I saw on a commercial. Same scene but missing the work place being powered on.
Well, there was nothing in that ad that would make me think the vehicles were powering anything.  That short night scene with the "workers" just looked like they were working in the vicinity of the truck.  Maybe when the guy was using the cutoff saw, if it was longer and actually showed the saw plugged into the truck....  I think you might have interpreted it to be powering the stuff, possibly based on your experience with your truck.
Lesson learned? Do some research.
  • 4 months later...
For the love of God, would someone please tell me how to actually fix the outlets on 2021 GM SIERRA that has been overloaded. And yes, I've checked the fuse 19AU under the hood and it tested fine. Is there by chance another in-line fuse for the inverter itself that could be the problem? My dealership was not able to help. If it's worth mentioning, both outlets in cab and on tailgate are not working.
On 5/24/2021 at 12:08 PM, Vigilante375 said:
I was very disappointed in this outlet too.  Just another gimmick to get people to look at the truck.  I've had multiple instances that I could have really used the outlet but it wouldn't power on the device I was trying to use for more than 1 second.
FWIW, if anyone wants something that CAN power household appliances and charge electric vehicles.  Go get an F150 with the 7500W inverter in the back.  It's a $750 option.  Can't beat that.  I wish Chevy did something like this and maybe they will in the near future.
Food for thought...
https://www.duracellpower.com/?utm_campaign=14747165745&utm_source=g_m&utm_medium=cpc&utm_content=547733638077&utm_term=b_duracell portable power station&adgroupid=131265315327&gclid=CjwKCAiAh_GNBhAHEiwAjOh3ZMbkl-xcqprCQwV5UL60ROFYNjr1tGepa0dvcHonu-8Dc9wQn3YrcxoCmgAQAvD_BwE
You might be able to plug it into the bed power outlet for trickle charging (not sure), run cables directly to your battery for recharging, or do something with solar panels possibly over your bed or on top of a camper.
No trying to be that guy, but is it switched on (or back on)?
Is the ignition on?
The outlets will not operate when the ignition is off,
the DC/AC switch is not pressed,
or the plug is not fully seated into the outlet.
On 10/2/2019 at 3:08 PM, mattsvtcobra said:
I did see that after I used it and asked the dealer.  But I do want to know why would you build a work truck through and through to put an elec outlet in the back that can't even support a common household blender? Seems dumb and not intuitive.
Yes!!!
    d.lowrey
    d.lowrey
  • Who's Online   2 Members, 0 Anonymous, 4,651 Guests (See full list)
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
