Two inch front level kit
EDDE
I am wanting to do a 2in front level kit on my 2018 crew cab Silverado. I simply would like to know what brand is the best. I am putting on 275 65 18 tires which I know of the plenty fine even without the 2-inch kit.
The lower shock mounted kits sold by Motofab are aluminum, so I prefer those over other manufacturers that are plastic.
You're right that a level is not needed.  I also agree with "nominion"  that Motofab makes good quality spacers.  They were my first choice after receiving good advice from other forum members.  I recommend that you go with the 1.5" lower shock spacer.  You will achieve the look you want and minimize the potentially negative aspects of level kits.
My 2014 I had I used the two inch, why do you suggest the 1.5?  I'm curious
https://motofablifts.com/i-30558221-07-19-chevy-gmc-silverado-sierra-1500-1-5-front-leveling-lift-kit-lm.html?ref=category:1390565
This one i assume?
Yes, this is the item I purchased.  I frequently pull a trailer and maintaining a little rake will reduce a nose high stance when towing.   I haven't installed my kit yet so hopefully others will comment.
I did the 1.5. Sometimes it looks nose  high, Sometimes level, sometimes nose low. I think it’s about perfect. If you are going with a brush guard I’d do 2-2.5.
I have 2018 Silverado crew cab 4wd.  I had a 1 3/4" rake measuring the wheel well openings but only a 1" rake measuring the rocker panels.  So I installed a 1" level kit to make the rocker panel level.  Now I have a 1/2" rake between the wheel wells ( barely noticeable) but the rocker panels are level and not going uphill.  Not all bodies are hung the same so you may need something different from other people.
Unless the decision for a kit is purely cost savings, the 5100s will do what you want way better and smoother than factory ride.
    rayredbone
    rayredbone
  • Who's Online   3 Members, 0 Anonymous, 307 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
