Any updates on this?  I bought a 2019 Silverado back in March, 2020.  Only have 5K miles on it and the other day I got "Service Steering Column Lock" in the message center.  While I'm not noticing anything wrong with the steering itself, at the same time this message comes on, the Driver's side front and rear windows will not go up or down.  Passenger side windows work fine.  Also, after I shut the truck off and open the door, the radio doesn't turn off.  Even if I lock the doors and walk away, it's still going.
This whole situations seems to come and go.  It went away for a day or two, then came back.  I called and made an appointment for Monday and of course, the error is gone now and the windows and radio work fine.  Hoping the issue comes back when it's time to drop my truck off.  Regardless I'd assume there will be some DTCs (Diagnostic Trouble Codes) set in the Truck's memory.
Wondering if anyone else had this issue and what the dealership had to do to fix it.
Thanks!
BigTom45
  • 5 weeks later...
I have 2020 HD Silverado it has about 7,900 miles on it i just started to hear a small nocking noise when i turn my steering back and forth to the left and right it feels like either play or something loose on the steering going to call dealer on Monday
What did the dealer say about the knocking.  My 2020 Sierra AT4 HD Diesel has started making the noise at 7,500 miles.  I have to go back to the dealer for the 5th time soon to get the brake pads replaced since they squeal really bad.  So many problems with this new truck.
We need to create a new thread on the squealing brakes, mine does it as well and I reported it a few days after I bought the truck last September and the dealers said oh its nothing they all do that. Bull. My Toyota sure doesn’t and neither should this truck that cost double what I paid for a Tundra.
I had two Tundras before this GMC with no problems, but since Toyota doesn't make anything as powerful I had to switch.  After trying to fix the brakes 3 times myself I found a service bulletin on one of the threads.  I think it was 20NA020.  Local GMC dealer replaced the pads with ones with a different compound.  Had mine done last week at no charge and so far they don't squeal.  The other GMC dealer I bought it from said normal noise and wasn't aware of the bulletin.  It came out in February 2020 and has been updated several times.  Print it and bring it with you.  The pads were actually back ordered due to demand so I had to wait a couple of weeks.
I’ll look around here for it but that service bulletin was for Clunking Noise from Rear of Vehicle (Re-torque Leaf Spring Bolts)
  • 5 months later...
I have had mine in once for this and now again it is locked up tight - The dealer claimed they just found some random codes the first time and could not find a problem.  1142 mile later it's broken again awaiting towing back to the dealer
I purchased a 2022 Silverado 2500 two weeks ago and experienced the first “Service Steering Column Lock” notice at about 170 miles. I took the truck into the dealership and they pulled the column apart. Two days later I had a new Steering lock installed. Today it failed again at 460 miles. Needless to say the truck is going back in for repair. I will wait until it occurs a third time which I am sure it will and start the Lemon law process. This is my first and last Chevy truck. I am beyond disappointed.
Hope all of y'all with this problem have better luck than I have had. Its a shame to have a nearly 60k truck that doesn’t make it to 500 miles before having issues.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
