Indeed! So they provide a feature that will help ya know when you're following too close? If ya can't figure that out you shouldn't be driving.
On 10/15/2019 at 10:05 AM, f8l vnm said:
100% agreed.  GM dropped The ball in the interior. Big time. So much so that RAM took 2nd place in sells for the first time ever. I know some of you are perfectly fine with the interior but majority of people have spoken and they think it’s a weak attempt. Again don’t agree with me ? Look at the sales numbers.  We’ll see what happens , I’m not expecting a miracle as GM just lacks in the interior dept.
The Dodge had the flashiest interior, big screen, more wood and chrome, the GM twins had a more basic, But, more usable interior.
The Ride and drive is what set the 2 makes apart, the GMs absolutely felt better planted to the road and much more solid build feel to it, but the Dodge’s steering, both had a bit of play to them, constantly moving wheel back and forth 1/2” or so, hey but it has flashier screens and trim.
It’s like  2 cowboys…
1 has a blue jeans, new boots and a nice shirt on.
1 has pressed jeans with a huge belt buckle, chrome tipped boots, rings and bracelets on wearing gobs of stetson cologne.
You pick your poison.
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
