Washing in between bed and cab
carguru
A couple of us were debating this morning on the best way to wash between the cab and bed.  I made a sponge with a stick to reach all the way down to the bottom.  Obviously the best way is to remove the bed, but that might be getting a little too :crazy: What do you guys use?
Nothing
Just spray some water down there.
Also i rarely wash the roof of my truck cause it is a PITA.  No one can see the roof hehe
I just spray some water down in there too.
For the roof, I just stand on my tool box, plus I have a step ladder that I use sometimes too.
I just sprayed water down there too when I had a truck.  And I stood in the back to wash the roof.  With my Blazer I just open a door and stand there to wash the roof then close the door and rinse.
:crazy: (no offense) ;)
I don't even bother trying to clean between there, I just spray some water in there.  As for the roof, I get in the bed and spray it then lay on the roof to scrub it or use the brush attachment on the washer if it isn't too dirty.   :crazy:
Reason this came up was, a guy I work with just bought a black Z.  He went muddin' this weekend and got tons of red clay all over.  He tried spraying water to get the clay off, but still has lots of reddish brown streaks that isn't coming off easily.  He tried several brushes, but all were to thick to fit.  We sort of had a side bet going that no one else ever cleans that area. :crazy:
I am pretty anal i clean inside the wheel wells very good.  I bet inside the wheel wells of my truck is cleaner than any other place
Hey Ryan, I'm with you on washing the wheelwells!  I've found that it you wash them every time you wash the truck they're alot easier to keep clean and it just takes a few extra seconds to do it.  Heck-I even keep the leaf springs and the part of the frame you can see around the rear wheels washed off. :lookaround:
But....I've never even tried to wash between the cab & bed!!   :crazy:
I clean my wheelwells at each wash.  Since we have a very sloping driveway, you can see the entire undercarriage of my truck, so I give it a wash everytime.  Guess I'm just too anal.   :crazy:
I spray out the whellwells good everytime I wash mine too.  I'm not in much mud very often so just spraying them usually does the trick.  But every now and then I go ahead a scrub them with a brush to make sure.
I think most, if not all of us are anal about keeping our truck clean.  Wheelwells are a definate must for cleaning.
Have you tried a dustmop?  Also, have you tried to access this area from under the truck?
I made a tool to get behind the cab and bed.  It is basically a sponge with a stick.  Attach the hose and it flows water through the sponge.  Pretty simple.  I'll have to post a couple of pics of it.  Not have very good luck posting pics at the moment.  I don't really think I want to wash from under the truck.  If I remember right the fuel tank and the muffler are in the way anyhow, so you would be limited by the space you can wash from underneath (plus you would probably get a little wet :) ).
Since the wheelwells and frame are exposed, imho it looks pretty bad if you don't clean under there.  :crazy:
Usually able to get 1 sponge length down between the bed/cab, also use the "open the door" and hold the "oh sh*t" handle to wash the roof, then close and rinse.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
    • I haven't seen inventory recovery from COVID.    In the few random times I 'build my own' truck or SUV, no one has the exact one I want.   GM has been working to lower incentives too for a long time.    A $500 incentive isn't getting me off the couch to go truck shopping.
