On 10/18/2019 at 7:13 PM, bass mechanic said:
Have any of you head a faint low frequency engine knock at idle from under the truck?
Seems like it doesn’t happen all the time but occasionally after it’s been driven and I start it up again.
Yes since day one and it gets louder as the engine reaches operating temperature. Had dealership work with GM and after a week they said it's normal. They gave me the ticking printout. I even had the truck put on their computer. I had them pull other new 2020s. The other new trucks did it also. I am stumped!!!
Heads up diesel knocking folks:
Quote
#PIP5711: 2020 6.6 L5P Duramax Warm Engine Idle Knock Noise - (Mar 3, 2020)
Condition: Customers may have a concern of a thumping or knocking noise coming from what sounds like the rear of the engine.
Cause: Characteristic noise being amplified by the transmission bell housing.
Correction
The noise described in this communication is audible in the interior and exterior of the vehicle but is more pronounced in the interior.
The noise is easiest to duplicate under the following conditions:
Engine at idle (about 600 RPM)
Engine oil temperature 113 - 185 degrees Fahrenheit (45 - 85 degrees Celsius)
Transmission in P/N
HVAC fan off
Radio off
To verify this is the noise described in this PI, remove the accessory drive auxiliary belt.  If the noise level is significantly reduced it should be considered characteristic of the 2020 MY truck and no further repair attempts should be made.
Engineering has provided the following procedure for belt removal, testing and installation:
  1. Remove the air cleaner housing.
  2. Remove intake air duct.
  3. Separate the charge air cooler (CAC) tube and position aside.
  4. Remove belt and position aside.
  5. Install CAC tube.
  6. Loosely place air box and intake duct back in place. (So you don’t set a code for sensor when starting.)
  7. Start engine and verify noise is gone.
  8. Remove loosely installed air box and intake duct.
  9. Separate CAC tube.
  10. Install belt.
  11. Install CAC tube.
  12. Install air box and duct.
  13.
Note: Do not run the vehicle more than three minutes without the auxiliary belt installed. Do not raise the RPM higher than idle with the belt removed.
This noise has no short or long term effects on the engine. Do not attempt repairs for this noise.
The short of it is...take it in, have them pull the belt.  Have them run it with you present if possible when the belt is off.
Edited by newdude
7 hours ago, Capt.Wackencracker said:
That's the exact location I picked up the noise with my stethoscope!
Don't see any drive belts nearby.
yeah but that GM document on belts/pulleys might help someone, so I posted it. It's not as if GM is on these forums providing concrete course of action for owners with noisy trucks or even basic info.
That photo displays the source of the thump at idle on my new truck.
I had to check twice, but you are correct!!! No belts nearby.
I wish they had a section regarding: "If the noise does not stop..."  Has anyone done this at home or at the dealer to check it?
My first chime in for this topic.
My 2020 Denali DRW is being built in 2 weeks so I will be checking it out closely.
I used to be a Chevy tech and finding stuff like this was my life.
I'll get my stethoscope out & will be all over this engine like a monkey on a muffin if there are any noises.
If you guys can let me know what the oil pressures are that you have been seeing at different temps and RPM's, that would also be a help because I'm curious to hear that the noise was less after the new oil pump was installed.
Also state whether the oil pres reading is from the dash gage, dash digital readout, scan tool or a master gage installed into the oil gallery somewhere.
There is always an explanation when something is different than it has been before.
I just picked up a Denali built in mid February and it is making the same noise.  To me it does sound like it is coming from the fan clutch.  I hope there is going to be a fix soon, definitely very annoying.
I just purchased my new 2020 duramax. With 600 miles on it. it now has a loud thumping noice at an idle after it warms up. I have owned a view never had this noise. Any suggestions?
Man, I've had the itch for a new High Country lately but I'll wait and see what happens with this knocking. I couldn't live with that noise! It would drive me crazy!
Edited by 20Bowtie14
Hey it's no big deal unless it gets worse over time.  Many of us old timers on this site remember and lived with the cold start knock and piston slap that was very evident on the 99+ 5.3L & 4.8L engines.  Most of those engines ended up serving us just fine with no long term effects.
Edited by Colossus
    • That should answer the maximum depth difference between the stock and the PPE so its not hugely lower. As to the PML pan, they don't make any claims that it fits the L8T with the same transmission and in fact leave their information confusing, however on the surface it says "for Duramax" and so its hard to say. I know a while back and not sure which brand it was that specifically stated that the extra capacity pan that particular company made did NOT fit the gas version.
    • There are several versions of the 5100's. Some for stock height, some for leveled, some for lifted.    Side note. I finally had a chance to tow with my 30' gooseneck with about 10,000 lbs of material on it this past week. Hands down the 5100's made the trailer towing much more stable and comfortable. I even had 10 cmu blocks in the bed. What a difference over the stock shocks.
    • According to PML, the stock pan is 4.3" deep - (PML info): Dimensions: at deepest area, PML pan is 7 inches, stock pan is 4.3 inches    PPE is 5.4" so roughly 1.1" deeper than stock
    • I had not realized that PPE has come out with a version of a cast aluminum oil pan specific to being able to fit onto the 10L1000 with the L8T engine sometime this spring. I was doubting that anyone would come out with something beyond what Dorman had in more of a direct factory pan swap. I see from one comment that is on the PPE site that they found the pan to be tighter to install then the factory unit and having to flex the exhaust down to fit it. I didn't lookup any specs if they have any as per how much lower it hangs but as it holds more oil and has fins outside the pan it would no doubt hang a certain amount lower.    I looked back at the site and they do have some depth measurements to get a rough comparison to the factory pan total height or hang down if you will at the front and rear of the pan so that will give a good idea how much further down this pan would end up being for ground clearance issues.    2024-2026 GM 6.6L Gas 10L1000 Heavy-Duty Cast Transmission Pan – Pacific Performance Engineering
    • I'm in constant amazement over the number of people that do oil maintenance by how they feel, what they were told, what materials cost, what brand A claims vs brand B.     Come to think of it, this behavior isn't exclusive to oil. 🤔 They drive this way too. 😬   There is a 20 plus page thread on BITOG on Mobil 1 Advanced Clean vs Valvoline Restore and Protect it would be amusing if it were not so........humanly pitiful.   Last Sunday we were are sitting at services and listening to a speaker talk about Jesus parable of the wide and narrow gates and he said something that hadn't dawned on me but totally fit the way people in general are about just about everything. He said there are so few people on the narrow path leading to a good reward not because the the narrow gate was hidden or hard to find but because the wide gate leading to a bad end it so darn easy and uncomplicated to follow!!!
