On my 2018 Tacoma I replaced all of the speakers and ran them off of just the factory head unit, world of difference in all aspects of sound.  It was not going win any awards for being super loud but for me in my daily driving it was great, had enough bass, the clarity was excellent and I rarely had to turn the volume a third of the way up.  I am wondering would I have similar results with my non Bose 19 SLE, if I swapped out the factory garbage for mid-grade JBLs like I did in the Tacoma?  Has anyone done this? Did it make a noticeable difference, I know that with no amp or sub it will still lack real bass but I am ok with that.
thanks
I know In the 14 to 18,s it didn’t work out to well the sound was horrible from the stock radio AMP.
Probably wouldn't hurt. GM OEM speaker are pretty low-end quality if you don't have Bose to say the least. My 2007.5 Dmax actually had all 4 speakers die, the back two cut then the front two but we hadn't noticed. The head unit seemed to function fine but I wondered what the odds are that all 4 speakers would crap out? Sure enough after some time here I figured out it was common, changed all 4 for some cheap JL's and it sounded a lot better than my 2013 HD non Bose. I can't complain about my 2018 HD's base stereo, but then again my subwoofer days are long behind me.
It's night and day difference. Replaced all door and front dash speakers with Alpine type S to the factory head unit and no amp and well worth the money.
Thanks for the info, what speaker did you use in the dash?  I am thinking just a tweeter but then consider going with a 3 1/2 two way.
thanks again
thanks again
On my last truck, I used a 3 1/2" jl c2 coax but was over powering the doors in terms of sound stage and had to bore out the mounting hole in order to fit. If ur going that route, u may have to cut more or less depending on how tall the speaker is down to the magnet. This time I used a 1" alpine type s tweeter and balanced everything out and the fact that I didnt want to CUT into a new truck.
Edited by 808 HI
3.5’s won’t fit. I had to cut a lot out and they still didn’t fit perfect. Get some 2.5 full range for the dash and better 6x9’s in the door. The 6x9’s made the biggest difference for me. I have the oem Bose stereo, it’s ok for stock but once you upgrade it you see what you’re missing. I’ll be using Morel CCWR 254’s in the new truck but it’ll be a 3 way active setup.
After I replaced the speakers the timing was way off so the sound comes from the right corner when you have the L/R balanced and needs to be faded to the right to balance it for the drivers seat.
I would recommend starting with a 6x9 that isn’t coax and go from there.
Edited by dw91
Do you have a 19/20 Bose system?  I thought it was difficult to replace just speakers due to something Bose does. If I can just swap speakers to upgrade the current sound, sounds like a good investment.
I have a 19 with the Bose system. You can just swap the speakers but get the connectors from crutchfield or you’ll end up having to cut the factory one off the oem speaker wires.
The timing ends up a bit of a mess and the infinity coax’s that I used are way to bright causing me to have the treble turned almost all the way down but it’s manageable and a heck of a lot better. Start with the 6x9’s though as I mentioned, you may not need to change the dash speakers.
Just do the whole thing - you might just end up doing it anyway. The stock amp sucks even with high sensitivity speakers. I started on my 13 non bose with some polk speakers all around; then I added an amp because they needed more power to run clean; then added a sub cause they were all treble. Its a slippery slope. If you need more treble, then get new speakers only; leave it alone if you cant do it all.
You can put together a decent system cheap on amz with a pioneer 4 channel amp bridgable amp, 2 front door speakers and sub - dont waste your money on rear speakers. An amp wire kit and a power on/rca adapter completes the set up. Takes a couple hours and easily under 350 bones (plus the manly satisfaction of accomplishment). You tube and forums will show you everything - I did my 1st install in my 40s with zero experience, and then did 4-5 more after that (wifes ride, boat, new trucks, etc.). Easy peasy japanesey...
Sent from my SM-T580 using Tapatalk
  • 9 months later...
Just ordered those same speaker, 6x9 front door and 6.5 rear door.  Got a really good deal on Crutchfield $145 shipped for everything including install brackets.
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
    • I have four that read by the dash 8 to 10% better than miles/pump calculations and I have one that is spot on.
