Looking to go with a 295/70r18 on stock rims for my trailboss, I have it narrowed down to the MasterCraft cxt, MasterCraft mxt and Falkin at3w. Just looking for opinions and maybe pictures of them on our trucks.  Thanks guys
I would go with the falkins. I read a lot of good reviews, I would told you to add the Hankook dynapro  to you list but last time I checked the price had went up.
A member on here had some trouble with Mastercraft tires. He also had balancing issues with the falkens - or maybe that was another member. Either way, I would tend to get the higher end tire as opposed to cheaping out, especially while increasing size  (harder to balance).
Have you considered nitto ridge grapplers?
I work at a tire shop we sell mastercraft tires never had a problem with them the cxt  are a commercial style off road tire we sell a lot of them to ranchers there more rock resistant then the mud terrains.  The falkens are just an all terrain more mild tread then the mastercraft. The new cooper at3xlt is a good looking tire too. The Toyo open country ct is a good tire as well.
He went through 4 different sets and they all shook. His issue is a truck problem not a tire issue.
I am also starting to have the same shake issue with my stock duratracs.
I recently went with Cooper at3 xlt's on my sierra 265/70r18, E rated. Made in USA, really nice tire. Originally wanted the falkens, but they weren't available in the size I wanted, also made overseas.
Edited by ForestryGuy
I'm almost positive the issue was fixed with different tires. May be wrong. There's been a few cases of this on here now
I just went with a set of Falkens (275/70/18) and I'm happy so far. Seems like a good do-it-all tire. Aggressive enough w/o being an MT tire. I can't speak for snow performance (yet), but I had a set on my Grand Cherokee and they did quite well in the Northeast.
  • 2 years later...
Anyone having issues with inner fender rubbing?
l’m getting ready to purchase a new set for my 2019 TrailBoss. Want to go with a 70 series tire in the 235-275 width. Mainly on road driving.
    Randy Ginoza
    Randy Ginoza
  • Who's Online   5 Members, 0 Anonymous, 2,096 Guests (See full list)
    • Paid $2.72 for E85 today.
    • Welcome back! No, it definitely doesn't pass the sniff test. Even "ceasefire" needs an alternative definition these days.    $5.29 at Kroger today
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • 2024 Silverado 2500 HD LTZ grille no camera Parts list   84603331 84913656 84913657 84913654 84913655 84911567 84911568 85646092 85646093 85797921 85797922   11570637  x10-15   grille/bumper bolts 11546500  x10      grille clips 11571006  x10      push/retainer clips 11546454  x6       nut retainers 11611609  x6       M5 bolts 11610700  x6       molding/trim retainers
    • And use RA's 5% discount code if you buy from them.  google for the code, one is always available.
