I have this rattle in the rear area, rear right passenger area. Sounds like its either coming from the rear window on the lower portion or the c pillar. I removed both headrest to see if that would fix it, and also removed the seat belt covers on the pillars as well. Placed the seats in the up position as well and still having issue. Still no fix, anyone else have any experience with this. Happens when i go over slight bumps and obviously larger bumps. Other than that the truck is pretty quiet except when i go over very rough bumps. Any suggestions you guys have would be great. Thanks!
I have the same issue, had it in my 2016 too. Do you have a sliding back glass? I got to the point where I assumed it's a cable or something that operates the window.
yea sliding glass, i'm almost 80% sure that's what it is, but cant pinpoint it. Ill have to have a friend or someone sit in the rear and try and see where its coming from
Not in my '19, but in my '16 I did.  It would only happen when I was driving alone.  At the time, I wasnt sure where the noise was coming from exactly but I knew it was on the right (passenger) side, somewhere in the mid/rear of the cab.  It was a subtle noise, light rattle over bumps or bumpy roads.  After combing thru the entire cab (several times) I finally figured out what it was, it was the Front, passenger seat belt clasp (the locking head) was tapping against the center Pillar.  I drove around a few times with the seatbelt in the lock position (same as it would be if someone was actually in the seat using it) and the noise completely went away.
If that's not it, you might consider taking it to the dealer, ask them to pop-off the door panels, one of the wiring harnesses for the window or door lock, might not have been secured (tethered) in the factory on the right side, and they can open it up and take a look.  You could do it too, but if it's under warranty, might as well have them...
Edited by Doolin-Dalton
I also have a noise like that in my  2019 High Country with 125 miles....
I wanted to stop and tear the truck apart! Thanks for the info. I will try the same thing.
2019 + rattles = B2B. ?   My '15 continues to be rattle and vibration free after four years of daily driving.  I wouldn't expect or accept anything less.  If you own a '19 and something rattles,  there is a flaw somewhere and you need to take advantage of your warranty coverage.  DIY repairs on a vehicle under full bumper to bumper coverage takes away one of the major advantages of purchasing a new vehicle, imo!
That would be the best idea (after taking it to the dealer) rather than having people on the internet all across the country with no access to your truck trying to diagnose it...
Tyler
Tyler
I took my 16 in and they couldn't find the rattle so sometimes reaching out to people across the country to see if they had the issue and found the fix makes sense.
I found out what it is, I’ll attach pictures in a bit, but it’s the plastic linkage that protects the rear slider power wire, looks like a chain but plastic
2 hours ago, oldmann said:
Tighten the jack under the seat.
That was the first thing I checked cuz it happened in my 15, but figured it out finally . All good
But in case anyone’s reads this thread looking for an answer, here are a few issues I found on the forum that cause a noise in the rear
1.) the headrests, pull them out and spread the prongs out just a little to snug up the fit
2.) Make sure your tire jack is secure
3.) The seat belt covers in the c pillars are loose and can rattle
4.) And if your hearing a pop once in a while,  it’s your spoiler on the outside of your car
5.) lastly, check the chain linkage for the rear slider power wire. It presses up against the glass
Edited by Memphis87
    Chris80s
    Chris80s
  • Who's Online   4 Members, 0 Anonymous, 906 Guests (See full list)
    • Still $3.01 with even more places at this price
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
