My little velcro trick seemed to work. I cut a 2" piece of velcro and used the "soft" side of it. Stuck it on the window and no more noise!
I tested opening and closing the window while watching the track and it doesn't interfere. I went with 2", but you could probably go for the length of the track, but if the window is open, you probably wont hear anything anyway.
IMG_20191221_163954.jpg.5f5125602c49ae8f1883edf64f27b943.jpgIMG_20191221_164226.jpg.d7471e9bfd9882584fbc9df5c37e83d2.jpgIMG_20191221_164248_1.jpg.f231b67ea7d22bb708ed1af66c14174a.jpg
Thank you!! My truck is dead quiet except for what I believe to be this rattle. Will try your fix, hoping it helps.
I moved the back window just enough to put some tension on the chain and it definitely seemed to help. I need to drive some more but it looks like the chain might be part of the issue.
Sent from my ONEPLUS A6013 using Tapatalk
What do you mean you moved the window? Like, you cracked it open a little bit?
You can press the button for a split second and it moves just slightly, maybe a 1/4". Seems like its still sealed since i dont get any wind noise but i have not tried with water. Mine stays in the garage so ill look when i drive in the rain or wash it.
Same rattle here.  Had a similar rattle in the past on a 2013 Silverado crew.  On that truck it was the latches that secured the back seat to the rear wall of the cab.  Got in the back of mine yesterday and pulled the head rests.  Sprung them ever so slightly at the bottom and the noise seems to be gone.  Mine seemed to be coming from the driver's side rear.  Made no difference if I had a rear passenger or not.  Fingers crossed, and if the noise returns, I'll keep on searching.
Edited by Foghorn19
A drive earlier today seems to confirm that nichos’ solution also fixed mine. I used a 4” strip of Velcro in the same place as he did, and the rattle over rough roads seems to be gone.
Great job nichos!
  • 9 months later...
I tried everything in here, was at wits ends then thought maybe, just maybe its coming from the outside. It seems to do it when the truck was "flexing"..sure enough, pushed on the rear spoiler in the back driver side and that "squeak" was making it through the cab causing the sound...no trying to figure out how to fix it.
I have less than 2,000 miles on my pickup and took it in and they said it's the leaf spring. They retort the leaf spring and put additional grease on it less than 250 miles later the rattle is back. They said to bring it in and they will add more lubricant which I replied I did not pay $40,000 to come in ever 250 miles for y'all to add more lubricant to it fix the damn thing
Edited by DonnieG
Misspelled
I have a rattle in the rear of mine also but I think its coming from the headliner. If I get back there and push up on it you can hear it smack the roof. Someone else on here said there are dense hard blocks of Styrofoam up there can hit the roof when you hit bumps etc. Gonna have them look at that when it goes in.
  • 3 months later...
I just bought 2022 1500 Denali today and I can’t hear anything while on the interstate but as soon as I slow down and go over any kind of bump I have a very loud rattle coming from the passenger side only has 125 miles on it. What do you guys think it is? I’m ocd and is driving me crazy. Help
Edited by Mike1022denali22
Headrest’s. Take them out and pull apart the rods holding them in
Also check your tire jack being properly secured
3rd check the bolts holding in the seats. They can be loose.
4th is spoiler.
5th is window itself
i had dealer end up fixing all of these like 1st month of ownership. Really quiet now.
take care.
  • 4 years later...
Just wanted to say thank you for posting this. Years later, your thread is still helping Silverado owners.
I bought my 2025 Silverado 1500 in January 2025, and I've had what feels like the exact same rattle since day one. After reading your findings, I believe my truck has the same issue with the cable carrier contacting the rear sliding window.
To be honest, I had pretty much given up on pursuing the issue. It wasn't until I recently drove another brand's pickup that I realized just how quiet their cabin was—and how noisy mine has been all along. On my truck, the rattle happens on almost any paved road, gets even worse on rougher pavement, and I can even hear it during braking and acceleration.
I actually referenced your thread when submitting my case to GM, hoping they'll recognize this as a recurring issue instead of treating it as an isolated incident. The reason I reached out to GM first is because my dealership told me they would need to keep the truck for at least two days just to diagnose the problem. I was concerned that even after two days, they still might not be able to identify the source of the rattle before giving the truck back to me. I had also asked a few dealerships about this issue during previous service visits, but none of them seemed to know what was causing it or had a solution. That's why I decided to contact GM directly first, hoping they might already have an official repair procedure or guidance for this issue.
I also hope GM eventually comes up with an official fix for this problem. I have a feeling there are many Silverado owners experiencing the same rattle, but most either choose to live with it or simply don't know what the cause is.
Really appreciate you taking the time to document your diagnosis. Your post is still making a difference years later.
    • I would have to read back to get a better picture in my mind of some of the other comments and what they were using for a driving scenario they based the fuel mileage off of. That is why the fuel mileage conversation is extremely difficult to make fair comparisons from. If I was to be living in town and only driving around town, light to light and some longer stretches that doesn't have a light every block, and the usual stop at a grocery store and the bank and so on and so forth, my fuel mileage even during the summer time would be so bad with my truck I don't even want to know how bad it would be !. Then add in winter time and idling to warm it up to clear the windows and driving through snowy streets etc, large heavy trucks with gas engines have NEVER been worth crap for fuel mileage and why some little pot licker of a car with wheelbarrow tires and a 1300 cc four cylinder non turbo engine was the ticket to using a mere fraction of the fuel over a full size pickup.    By the way my truck has the 34" tires as its a HC but not the BFG KO3 tires ( that was an option for my truck but the sales guy couldn't figure out what the tires actually were so that never got on the order until it was too late to change the truck order ). So what fuel mileage your getting actually sounds good for "town driving" and with my truck when I go to town the fuel mileage keeps increasing as I get closer to town because it takes quite a while to get the driveline oils warmed up ( and why it always shows better fuel mileage on the return trip from town because its already warmed up ) but once I am in town that fuel mileage average just keeps dropping the more I mess around town and then has to recover back to something reasonable again by the time I get home for an over all average.    I'd be curious what your sticker says for the factory weight of your truck, mine is close around that 7700 lb due to the options it has. But anyway the long and short is, vehicle weight, higher rolling resistance heavy tires and a hefty driveline and a relatively large gas engine make for crap fuel mileage in stop and go scenarios, all one can do is drive it easy off the line at each stop and as my dad had said over the years, drive like a raw egg is under your foot and that's the best one can do. Years back with a carbed engine and if the carb was getting a bit out of tune etc as would the ignition system, the fuel mileage on pickups with larger engines was just awful compared to what your getting. We pay the fuel price penalty for driving HD trucks over some little vehicle, that is the reality.
    • We had two Toyota’s with that engine in the mid 80s. We had 50 gallon fuel tanks, a toolbox full of tools, an air compressor and assorted parts for our equipment. We beat those up and down pipeline ROWs until we started buying diesel trucks. Then they became parts runners and first vehicles for our teenagers first cars. Our shop Forman wrecked them both two years apart when we hired him out of high school as an apprentice. Good thing he’s an excellent mechanic. It took awhile before he could be called a good driver.
    • I have a 2025 GMC Canyon Denali.   On a trip recently the engine failed.  The dealership diagnosed a bent valve and says there is a service bulletin that indicates to 'relace the engine'.  The truck only has about 14K miles and is under warranty.   The failure occurred 5/11/2026.   So far I have worked with GM Customer Assistance and Roadside Assistance.  Evidently no engines are available and nobody will offer a date when a new one will be.   Coming up on two months with no repair or timeline and no loaner from the dealership.   GMC Customer Assistance is 'ghosting' me and keeps closing the cases I've opened with no resolution.   Hoping someone can help me on how to escalate this issue.
