AFM Failure engine bad 92k miles
 Well my engine ran low on oil thanks to a chain shop
 Not a standard failure
they Failed to secure  my oil filter and plug
it sounded just like this ...  the chain shop was sending there insurance adjuster..
 I know the VVT system is sensitive to oil loss(and cleanliness ) compared to the normal push rod setup..... I spend a lot of money buying this and maintenance costs only for someone else to screw up my engine :(
 it sucks   I was paying a lot of money to have the oil changes done every 4k miles  on this Non oil burner (i still have not lost any oil since )
it was pretty cold last night 27f here in  the desert  this is what my start up sounds like earlier today...
 it leaked out in a short time frame of 164miles   it's not like it would have mattered if I checked it every 1k miles(but i do anyways)
 If i had a DirtyMAX  Hoe that sound would be fine!
The cummins is so wimpy sounding.  Bah.  Sorry you got screwed like that though.
unfortunately the damage is worse then first thought
ROD knock  I can hear a faint rod knock  on  Bank 1(AFM side   since it would have been mostly running in V4 mode most of the drive)
cylinder  #3 or #5 on cold starting ..  I'll use another camera with a better microphone to pick it out..
Did you contact the people that did the oil change and ask that they make it right?
Sorry man.
Unforunately you're not the only one in this situation.
Fast lube shops = fast turn around, inexperianced employees and improper supervision.
And crappy cheapy filters that are in bypass by 3000 miles
Sorry to hear this but you know that old saying the “you get what you paid for” saying, still stands firm. Hope you get everything figured out, good luck!
Sent from Above
They said there were going to send someone  out   that was a week ago  ..
there is also a faint rod knock as well
valves are higher tone slap
i can hear rod knock  on #1 or #3 or #5
 on cold start
Lol... if the duramax were that impressive, it would in every type of equipment  like the Cummins - but it is not.
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 636 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
