On 4/27/2020 at 8:53 PM, MTU Alum said:
I don't have alot of info to add.  It sounds like either a connection issue or some type of software bug.  I have had to setup about 50 trailers for demos but once I learned some of the setup issues, I haven't worked through any type of issues like you have mentioned.  Wish I had more to add.
#iworkforGM
HEY MTU-
I ask because you have been very helpful with this stuff. Any idea why my "invisible" camera mode needs to be re-calibrated every time I hook up, or have a gas station break, or stop for food? It's pain to drive the length of a football field while going 5 miles an hour to calibrate this thing every time.
27 minutes ago, migrabill said:
HEY MTU-
I don't.  I assume you are selecting your saved trailer profile when hooking up.  You shouldn't have to re-calibrate after you have done it once.  Let me see if anyone has any ideas to try.
#iworkforGM
On 5/5/2020 at 7:56 PM, migrabill said:
HEY MTU-
Ok.  I asked around and here are a few things to try and make sure of.
1.  I assume you are selecting your trailer profile at startup and not changing any the of the dimensions.  If you change any of the dimensions it will cause you to re-calibrate.
2.  Just confirming that you are getting a yellow status bar and showing calibration being done on the Transparent view after each startup?    You have to be going 10 mph for the transparent to work after a key up.
3.  If it is really calibrating after each key cycle, I was told after the calibration is complete and transparent is visible to shut the vehicle off and let it the truck go asleep.   Basically, shut the truck off and open/close driver's door and wait until the Onstar green light goes out.    From your post, this should have happened at your gas station and food breaks.    When the module goes to sleep, it should write the calibration values in memory.
4.  Its probably worth trying creating a new trailer profile with the same dimensions and see if for some reason that profile is corrupted.
5.  Take some pictures in transparent view with it calibrating and once the calibration is complete.    If it is calibrating, in the transparent view you should see the view with the two mirror cameras with the trailer camera in the middle with a yellow status bar at the bottom of the screen.
6.   Take to Dealer and see if there are any codes for loss of communication between the CSM (Radio Display module) and VPM (Camera module).
#iworkforGM.
On 4/27/2020 at 5:13 PM, ShotgunZ71 said:
I have not tried a different truck yet. It really does seem like a power issue with the way it "knows" a camera is there, but shows no picture. Then, when unplugging and then plugging into the other port, it is great. I had issues from the start with the hookup process, powering down, etc, but this issue has remained. It will work great, then go out, then work again. The biggest problem is when it decides NOT to work when I need it the most, like backing it a tight spot or checking spacing. I may just try it on the interior camera port next trip and see how it does.
Hey Shotgun...
I have a few more data points; have you learned anything new?
I've been having radio problems (particularly with XM) so I took my truck in for service.  While there, I told my service advisor about the problems with the trailer camera.  Since they couldn't replicate either issue, they informed me that there were no problems.  When it arrived, I filled in the customer satisfaction survey with my true feelings.  A few weeks later, I got a phone call from GM Corporate wanting to know more about my issues.  They set up a service appointment with a different GMC dealer, who listened to my issues and did a fair amount of diagnostics.  The XM radio problems are not unique to me, but it appears to be a problem with SiriusXM and not GM.  We are awaiting word on resolution.  As for my camera problems, my service advisor told me that the camera system "threw a lot of codes" so they know something is wrong.  They are awaiting some parts to fix my issue, which are apparently on backorder at the moment.  He's been a bit cagey with details, but I'll post here when I learn any specifics.
After nearly a month, I got my truck back (radio still not working) this week.  Today, I picked up my Airstream.  Initially, the backup camera / invisible trailer view worked per design.   After a few miles, it froze then eventually went black--just like before.  I reset the trailer plug, and the camera worked again.  But this time, I never put it into "invisible trailer" view; instead, I left the rear view camera on for several miles until I reached my destination.  The camera worked the entire time!  So here's my theory:  The camera works fine, but the invisible trailer processor is causing the apparent problems.
Shotgun, I have a request for you:  The next time you're pulling your trailer, can you NOT use invisible trailer view and just leave it in rear view only?  Let's see how that works for someone other than me.  We'll have the trailer back out in a week and a half, at which time I'll try further diagnoses along these lines.  Hopefully you can help shed some light on this.  My XM problems and trailer camera problems are still highly correlated with each other, so I still think they are somehow related....
Thanks,
   Jayson
20 minutes ago, dab5577 said:
Have you tried to refresh the radio to resolve XM radio? Mine has been acting weird and stopped working Sunday and refreshing my radio ID fixed it. It took a few mins but was fixed in a few miles after submitting.
Yes, I've tried this about 20 times, and so has the service department at the dealer.  This has had no impact.
I'm having some really specific, strange issues with the radio.  My service advisor reports that GM is aware that some trucks are having these same issues, but they have not yet identified a fix.  Most recently, GM thinks the problems are on SiriusXM's end.
I'm suspicious of their assessment, because my radio problems are exacerbated by plugging in trailer the 7-way plug.
I figured they had tried all kinds of stuff, but wanted to throw it out there.
Hope you get a resolution soon.
13 hours ago, jaybauman said:
Hey Shotgun...
Thanks,
   Jayson
Jay - I don't use invisible trailer as my camera placement is too high and trailer is too long for it to calibrate correctly. The only views I have is rear-view only and rear-view with side mirror cameras. I'll see if it's any better next trip or if it works better using the interior camera port on the bumper.
Interesting that they found codes on the system. Next time mine goes for service, I'll mention it to them and have them check it out. Hope they narrow yours down and get it squared away. Maybe the processor is the issue, like you stated, and GM will update trucks that have the issue.
Ok....then next time, just use the pure rear view.  Mine has "locked up" in the combination rear/side view; when I was only using rear view, it worked the entire trip.
Interesting topics.
We have had the XM issues from time to time where it doesn't seem to connect. If I change the channel it starts playing an I can go back to the normal channel. Last time I got in the truck it worked ok.
On camera issues ours is a travel trailer so camera is above the rear window and I figure i is to high to calibrate as we have tried it a couple of times.
Took the trailer to have serviced about 60 miles away. Camera did fine as it always had. When we picked up trailer the camera would work. After reading the suggestions on here I hooked the truck up yesterday after letting the buss go to sleep. It worked fine.
Funny as every other time I hooked and it worked. the engine was running. Don't know if I hooked up the 7 pin connector first or the camera connection. I do know once or twice I had to unplug the camera and plug it back in while my wife watched to see the camera start working,
Will be trying it again in a few days so will be interesting to see if it works.
Wish the trailer pressures could be displayed on the main dash display.
Thanks for all the info...
I tried it using rear view only, still froze intermittently and then went blank. I then unplugged it and plugged it into the inside trailer port and it did the same thing. Here’s the kicker, it seems to freeze up more when moving and it’s trying to show the video. Your dealer may be on to something about the processors. Maybe they can’t handle the active video, but still or slow, they do okay sometimes ?
That's not the result I was hoping to hear.  Thanks for the update.
We're camping again next weekend, so I'll try a few more diagnostics and report back if I learn anything interesting.
Well it would be nice if GM would offer a camera and the options necessary for us guys with the big 38+ ft 5 er's.  I would love to put the camera on the back and have everything incorporated on one screen.  Currently the camera they offer does not have a long enough cable.  Plus why wouldn't they put the stinkin video ports in the bed of the truck also.  That right there tells me they never thought about using a camera on a gooseneck or 5th wheel.   Doesn't make sense to me.  I keep looking for the style plug they are using  to come up with something on my own. Does anyone have an idea?  Problem is right now these trucks are so new and  if we want these options we have to come up with solutions ourselves.  I will give it to GM they put some thought into it but it seems they forgot about us guys with the big trailers when it comes to the optional cameras.
Below is a link that tells you what to buy from where to relocate the bumper plug into the bed. I have done it and it was very easy but my camera is still on backorder so I have not been able to try it out.
https://www.gm-trucks.com/forums/index.php?/topic/235530-Help-W/-relocating-camera-port-from-bumper-to-bed-for-5th-wheel,#entry2388376
    • I gotta say, I'm enjoying your narration. The troubles you've been having are amusing as you describe them. It's good to see that you're finally getting some satisfaction out the old beast though.
    • Declaring victory would upset the demons that possess this Blazer, so I won't. But I did make progress today--after it put up a fight. Always a fight.   I had the day off so I spent the morning cleaning up the shop and I thought I'd get ahead of things by filling the cooling system in prep for the final part I needed to arrive: the driver's side knock sensor. Glug, glug, glug....and then the unmistakable sound of liquid hitting the shop floor. It induces the same chagrin when the sonar and targeting laser temporarily malfunction during a late night bladder evacuation over the toilet with the bathroom light off. D'OH!!! That made a mess...   Oh, hey, that knock sensor I removed? It threads into a wet port. Who knew?! Learn something new every day. Put a pin in that chore, I'll fill it the rest of the way later.   The knock sensor arrived at about 1pm. I threaded it in, connected the wire, filled up the coolant, checked for leaks, and... drumroll.... fingers crossed for a perfect start, excellent timing, model fuel trims, and ...no squeaks... Here goes.....   No, it didn't start. At all. I cranked it a few times and it wasn't sounding good. Furthermore, I heard leaking again. Jesus H Tapdancing Christ, stop leaking all over the dang floor. This time I had accidentally overfilled the coolant reservoir and the churn of the water pump via cranking caused a bit to burp out. Ok, just, breathe... Put the flamethrower down. Dang thing wouldn't burn anyway, leaks too much...   Did you know the rotation of a round crank sensor in a round hole, matters? I do now. Took me about half hour to retrace steps and realize what I had done. Then it started right up.   No squeaks. The squeak was the old balancer.   Once it entered closed loop, fuel trims are dead on, hovering right around zero at idle. No more -30%. I'll credit the injector rebuild on that one.   Timing? I think there's an OBD 1.5 translation error with my Actron scanner. It's anywhere from -20 to -30 at idle, sometimes as high as -40 cruising. Sorry, the engine just isn't running that smoothly at -40 degrees ignition advance. It's just not. It's smooth all through the rev range and has decent power. I'm going to have to trust the seat of my pants on this one.   The new exhaust is very quiet. The old catalytic converter? Not melted, but definitely not healthy. Rains glitter when you turn it on its end...all the precious metal is flaking out. Once the new exhaust system burned in/smoked off a bit, the engine's exhaust smell is normal again. Not that I'd recommend going around huffing car exhaust, but, you know what I mean?   One problem to correct. The new exhaust has the opposite problem of the old spliced up exhaust. It wants to hit the floor where the old one wanted to rest on the cross member. Happy medium, please? Still noodling on that one, need to look at how I can adjust some hangers.   I don't know what's next. On one hand I want to run away from this thing as far and as fast as I can -- there have been a lot of NOT fun moments. On the other, now that it kinda drives nice, maybe drive it around for a little bit?   Shhh... it's not currently dripping oil all over the floor. I can see just a little wet at the bottom of the timing cover where it meets the oil pan seal. It's not dripping multiple drops with every ignition cycle, in fact, after some driving this evening it has yet to even form a drop that could drip off yet. But the weekend is young... I fully expect this could turn into Exxon Valdez by Sunday. Because this Blazer hates me. LOL.
    • About that:   Once upon a time in a land far far away lived a car company that was shy about taking your money and wanted to be sure that they gave you more that you asked for so that you'd come back. No really, not a fairytale. 😱   But after the field got thinned out enough to limit the competition it seemed good enough to give you only what you asked for. Fair enough I say but in such a market you have to give something the others are not or they go to the one who does. Gimmicks or glitz. Oh, fins and chrome. Yea, shinny crow like cars. Yum.    Field narrows a bit more and 'brand loyalty' becomes a thing and the minute it does they start thinking to themselves, "Could we make more money if we gave them less than they expect and they will hang in there for brand and comfort with the known?" They gave it a try and da*n, it worked!!    Well, what if we teach them, groom them into believing that less is "Normal" and cut some more corners. Will that work? Oh heck yea!    🤔 I wonder, can we give then WAY less than they expect and make them mad enough to spit nails and STILL get them to pay up? Sure, if we get everyone else to do the same so that the choice is less or nothing at all. How would be do that? Platform sharing.  What a concept, right?  Steal like there is no tomorrow and it's legal too!    Truth is no one is going to give up driving, not for very long. The Gen Z crowd is fine with it and will be as long as someone not Gen Z will haul them around. At some point we all die.    Economic voting only works if you cast a NO vote now and again and enough of them to get dumb and dumber to wise up. Well, that's how I was taught anyway. And it should have worked. Would have worked. But the Bail out!!   Look, you have another choice if  you take that bag off your head. If the dumb it down to some predetermined expectation of how John Q Public will use it the, that is under design it to failure they you use it to a lower stress mode. D'ho!    A 1950 Royal Enfield Bullet 500 will go anywhere a Suzuki Hayabusa will and for just as long. But you will have to treat it for what it is and not for what you wish it was.
    • Maybe I was just too unlucky, but I had nothing but bad luck with Bridgestones. Out of 3 sets, they all started losing a lot of air when they got down to about 1/2 tread life, and at that point also wet traction suffered more than it should have. Also, the only tire I ever had in my 60 years of driving that had a side wall blow out was a Bridgestone.   I'm currently running Goodyear Wrangler Workhorse AT and am very happy with them.
    • maybe when the trip is over, check all the other joints in the front end, like all the ball joints, tie rods, pitman & idler arms, etc...
