02 Chevy Silverado 5.3 liter jerking when accelerating
Chevy9880
Maybe overlooking things.  What kind of fuel?  Has the fuel filter been changed?  It is easy to get to under the driver side door on the frame rail.
Check all the plugs and wires.
Yeah, that's a good point, too. Never know. Could've run some water through the system. With today's fuel, that wouldn't be the first time.
Nice, but too new for me. If it was a '72 or older, then I'd be interested. Thanks, though. :cheers:
12 minutes ago, Jsdirt said:
Gotta love electronics. No rhyme or reason to anything. People wonder why I miss the old days of carburetors and points! Problems were cut and dry, and ALWAYS fixable with basic hand tools, and little to ZERO money.
There's a possibility you had a pin fitment issue at the connector on the old one, and unplugging, and plugging it back in fixed the connection. Hopefully it remains fixed.
I like the 5.3 after 3k RPM. Before that, they're slugs, IMO - the old 80's 350's (tuned correctly) will stomp them off the line. I've owned many that would. In fact, our '86 Grand Marquis with the 302 / 5.0 will jump my Silverado off the line with ease, spinning 1 tire (the one-tire fire, lol) the whole way - 2.73 gears back there, too. The Silverado with 3.73's can't leave rubber from a dead stop unless there's sand, or rain. If they'd build these things with the torque of the 80's and the horsepower of today, I'd be a happy camper.
Agreed but I have to say that I like that the response from the pedal to power is still good no delay when I hit the gas. A lot of the newer engines lack the response time.
My throttle response is good, but the power just isn't there. Been that way since it rolled off the showroom floor, and other trucks I test drove that year with the 5.3 were all the same. Even with the Corsa cat back, cold air intake, and Hypertech program, it's still a total dog off the line.
When I drove my buddy's Hemi for the first time, I lit the tires up, not even trying - that truck had FANTASTIC throttle response and torque. Night and day different from mine.
My 2002 runs great.  The tune from Black Bear Performance really woke it up and I can spin the rear tires off the line.  Before the tune it would just move along.  :lol:
I would love to get one, but I can't trust this thing as it is. Differential completely smoked with missing tips of spider gears at 97k miles, and poor oil analysis results going back to around 60-70k miles (started the oil burning at 50k). It can barely handle the Hypertech mechanic-in-a-can tune, lol.
Might not have anything to do with it but on my 2002, it started an oil leak that dripped on the concrete.  I can't stand leaks.  So in the process of finding the leak, I changed out the intake gasket and the cover below that gasket along with the valve covers.  Now before all this and before the leak it would use a qt of oil in 5k miles and would smoke on start up if I towed my trailer, (aka putting a load on the engine) but once I changed out those gaskets, it doesn't use any oil now and no more smoke on start up.  Just an  FYI.  Currently have 197k and all is well.
Wouldn't shock me one bit if the gaskets failed at 60k miles on mine. I don't even have 100k on her yet. Been nothing but trouble since day 1.
Thanks for the heads up. Might smoke test her if I ever get the motivation, just to see.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
