It's a rubber o-ring style gasket, they flatten out over time along with all the hot/cold cycles. It's going to cause a leak someday.
Just wanted to say thank you to all of you on here at the time I have not replaced my gaskets yet but if I'm on the highway going 65 in overdrive and a very slight pressure on the gas pedal the truck will shape does that seem like the vacuum leak what caused that just on throttle tip-in
Well,not the first time I'm wrong,so focus on left bank,per code,test intake gasket with water in spray bottle,rpm change? during test?,not a perfect test either,can't get at underside ,other, swap 02sensors,side to side,see if code follows?
I answered your question already Scott, a few posts up about why they leak.
Bank 1 is drivers side, bank 2 is passenger side.
EGR was phased out after 2000-2001 on the 4.8/5.3/6.0's.
That's where I always mess up,returnless fuel system,no egr, return system,yes,g.m. always emptying the parts bin, before a change,got to keep on your toes with this stuff,I'm still thinking about getting a horse,lol
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • This can be done.  It is not cheap and requires an instrument cluster swap with custom programming, new steering wheel with the controls on it, and a special jumper harness.   The cluster upgrade - 12.3” Digital Cluster Upgrade – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The wheel upgrade - Steering Wheel Upgrade Kit – 2022.5–2026 Silverado / Sierra (T1 Refresh Pickup) - WAMS   The column harness upgrade - 2019 - 2026 Silverado / Sierra: Steering Wheel LIN Bus Harness - Harness Dr. - DIY Done Right     The problem with doing all of this?  You pretty much can't have any programming done to your truck that involves the cluster ever again.  The dealer won't be able to program the cluster as GM's system will only pull data for the cluster the truck came with.  So it would be advised also to turn off over the air updates.   TLDR;  Should have bought an LT double cab?  You'd have a power seat, the wheel controls, the cluster, all things that you've been seeking in your various posts so far about your new WT regular cab.
    • I was unaware of that, thanks for updating me.
