Hey guys was just curious to see if anyone has this truck bed topper? The thought of a topper is growing on me and this one caught my eye. I’ve included pictures from their site on a 2019. Please share your experience with them.
thanks
I just got an ARE. Z-Series. It works well but Im not a huge fan of the appearance. Because of that slight dip on the back of the truck roof they they are not level with most of the cab. My 2013 with ARE topper is level with the whole roof and  looks better IMO. Still a quality product and I like all the protected space it provides. Now I tell my wife I love my truck from the inside out because she keep calling it a grampa truck! LOL
Edited by Minnvmax
Just spoke with my local ARE dealer, he talked me into getting the Z series as well as it’s $250 dollars cheaper just for the black stripe of line-x. Could you possibly post some pictures of your “grandpa” truck LMAO
  • 1 month later...
I ordered a ARE Z2 series 12-13-19 for my 2019 Sierra Denali crew cab. Just got word it should be here this week because it was shipped Saturday from Ohio factory. Can't wait to get it on. I've had a Z series for the past 17 years because when we had our first kids and having a truck, I needed to keep the stroller and groceries dry. Now I can't go without one. Nice to go on vacation and keep everything dry in the camper shell. They just don't make the Z series anymore and make Z2 now.
I just got an ARE V, or CX (whatever is cheaper), when the ARE dealer installed the he tapped into the third brake wire and it threw a 'service trailer brake code' in the DIC on the way home. I took it to the dealer and he had trailer plug tester-thingy. Tester showed that the plug was live but nothing else worked (lights, turn signal etc). Dealer literally shrugged his shoulders and said "eh, take it to the dealer".... I was NOT happy of his casual attitude. I took it home, plugged my trailer into it and everything worked. The "service trailer brake" hasn't been back (though I did not get to test trailer brakes yet).
Now i noticed the passenger side of the cap is leaking!!! I have to take it back this week.
Had ad a leer for 11 years and it didn't leak once.
Edited by mistaare
Grammer
  • 4 years later...
I’ve had my z series for about 4 years, I ordered it as soon as I bought the truck. Also have the cap pack drawer in it. I’ve been very happy with it. Though, I saw the overland series it isn’t any stronger than the Z. It just has some bed liner on it, as if you’re going to protect it from pinstriping. You won’t. Not if you’re actually using it in the woods, otherwise it’s just a “mall-crawler”. Not worth the extra 250. The rooftop load bearing rating is the same on both. If you need a higher roof weight look at RSI or another metal topper.
    • That dog don't hunt. 😏   First, a 2025 with 12K on the clock AND idled for a year nonstop is false on it's face; this is 2026. You can do one or the other but not both.    Second, ENGINE HOURS are absolutely available. The rest is third grade math. Micky Mouse scanner he got out of a box of Cracker Jacks OR an ID10T error.    Third, if they ran it out of oil "Several times" that motor is boned on the first hit.    Does this guy think piling higher makes it stink less?
    • That's interesting, I assume that would add to the cost of the oil but also I was forgetting to bring up the issue of the low tension rings allowing more oil past which in turn forces the cats to have more oil additives pass through them that wouldn't otherwise so they are creating that problem and of course its all in the name of fuel economy. Mind you the other issue would be the lack of additives that fight the formation of carbon within the piston ring grooves which turn the engine into an oil burner and with in this GM forums case is your average off the shelf Dexos licensed oil, meanwhile the other off the shelf oil being Valvoline's R&P isn't licensed and the only one that is which is that certain Mobil oil that came out recently ( its not even being marketed in Canada ) and only a fraction of vehicle owners are going to be using it out of all the other oils on the shelf or the quickie lube bay that meet the Dexos spec by way of actual licensing.    Also I suspect that its an easy excuse to pool the non turbo DI engines in with the turbo DI engines and design the oil to not have LSPI issues in the most demanding engines and short change the naturally aspirated DI by not offering a higher concentration of additive package they could handle and still not be at risk of LSPI.    I wonder if Amsoil flipped the switch just lately and did whatever packaging designation at the same time as I wonder what oil formulation I would have bought in May, of course I don't know when it was packaged at the factory vs how long it was in storage at the Edmonton warehouse. I know its been said at least in the past that the big players switch over to a reformulated oil but the packaging has not changed until they make that move as well so there is that cross over time where its a new formulation in a predated formula marked package.
    • Hmm. A real reason to not just use the odometer to determine OCI?
    • Sad thing is that this doesn't have to be the case. LSPI can be solved without a reduction in TBN. Swap Ca for Mg.  Cats are not a issue if the OEM can get a ring and valve guide seal even at SN levels of SAPS. Dizzy is purring like a kitten with a bowl of warm milk. 200K of Full SAPS oil and zero detonation issues and nice a clean inside and out. This shouldn't be an issue. It isn't 1920.    Tell ya what AMSOIL SS is excellent at, internal cleanliness. The new formula is even a step up from their already outstanding cleanliness levels. Can't say the OEM offering is quite that clean. There marketing suggest the SS is cleaner.     That is the only defense with at shelf oil. Nothing wrong with them if you ignore the marketing and OEM 'recommended' OCI and use a thimble full of common sense. 😉 You go sir.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
