I doubt anyone has changed their fuel filter yet but if they have are you having trouble resetting the fuel filter percentage on the computer?  Mine won't reset to 100%.
You are doing this "To reset the system,press and hold the thumbwheel fortwo seconds while Fuel Filter LifeRemaining is displayed on the DIC."?
What happens for you when you do?
I did that and also 5 seconds or longer and it beeps but nothing happens.  When you press the wheel it switches over to the confirmation page that asks if you want to reset it, I select yes and it stays at 28%.  When I hold the wheel down for any amount of time it beeps but doesn't switch to the other screen.
On my 18, you had to press the center button and hold it for 5 seconds.  After the beep, stop pressing the button and cycle the key.  Then it would reset to 100%.
With the push button, I would presume it's all done the same.  This was all done without the engine actually running though.
Unfortunately you can't actually get to that menu if the truck isn't running on the new ones.  I've done what the manual says and it won't work, so I'm assuming there is an issue.  Looks like it'll be another trip back to the dealer.
  • 10 months later...
I finally got this figured out in my 2020 hd....you have to push and hold the steering wheel toggle button down for a few seconds and then it will beep...the percent will remain the same...shut the truck off and turn back on and it will reset...pain in the A.
if you have push button start: hold the start button (without foot on the brake) for 5 seconds. that will put the truck into run mode without the truck running. then reset the filter. turn the ignition off and it should be reset on next power up
Thanks. This worked for me finally. The dealer wasn’t even sure how to do it. Lol.
i took my 2020 silverado 2500 diesel to the dealer today and had the fuel filter replaced.  They couldn't reset it.  So I got on line and notice your email.  It worked great.  hold the start button for 5 seconds without touching the brake pedal.  then when in accessory mode push in the center button on the right side for 2 seconds and it immediately went to 100%.
thanks
  • 3 years later...
thanks kylant just found your old post, had this issue after changing filter myself & DIC wouldn't reset, my '22 2500 Duramax reset immediately following your advice.
    • There's some truth to the above, but also, she's selling fullsize trucks and bread/butter CUV's like hotcakes, meanwhile, extracting GM's pickups from the deep discounting sales game.   GM's stock has held its own during her tenure, and the more recent buybacks are delivering cash back to investors and signal confidence in their direction forward. Even with the EV losses.   GM is an example of a modern publicly traded company. The #1 goal of any publicly traded company is to deliver the most value possible to shareholders. Despite being a car company, building the best car isn't GM's path to delivering maximum shareholder value.   McDonalds doesn't make the best burger, or the best coffee.   I've mentioned in another thread, I really don't / won't ever understand Cadillac or Buick in a modern context. Both brands are completely dead to me. I'll cede that the Escalade is a nice SUV, but the brand and nameplate mean nothing to me, and GM will never persuade me to pay north of $170k for a gussied-up Tahoe or Burb. Other people don't mind doing that and that's their purview.   The C8 shares absolutely nothing in common with any other current Chevrolet or Corvette on the market. Since its introduction 8 years ago, it's developed quite the following. It did what other Corvettes couldn't do: reduce the average age of its buyer. GM has something there, and I see them investing in the car. They'd better not mess that up.   We've successfully derailed Grumpy's thread again, but I think this one is meant to be more of a random thought thread so a little wandering is probably OK.
    • Sliding doors ftw   Also, Sienna ftw as well.  The in-laws got a 2024-2025 recently when their 2019 sienna was totaled due to a deer back in June.  They've been getting 38-40mpg on the 65mph highway they live on.
    • Forgot to mention that this started after changing the oil I use mobile 1 full syn with mobile one filter but I did add pro lube additive and was the first time doing so and is making me wonder just can't see why that would matter
    • I apologize for long post put going to try to explain everything. Parts replaced so far: Cam sensor Crank sensor Cam phaser valve Cam phaser solenoid Fuel pump Maf 1 injector Pcm Pdm   So about 2 weeks ago coming off the highway my 2007 yukon xl with the 6.2 stalled and would restart. Had unit towed back to house and I messed around with relays and unit started. Drove it the next day and same thing. Had it towed again. Scanned unit and had code p0300 with misfire data showing mainly cylinder 7 but I know that won't cause a no start. Measure fuel pressure and found only 42 psi replaced pump to have unit stall again and not restart. This time I stayed on back roads and just waited for it to restart about 30 to 60 min. During this time I found I have no injector pulse but have good power at injectors. Started unplugging 1 injector at a time and found when unplugging cylinder 7 pulse came back so i changed injecto and same issue. Turns out unit just happen to ready to start at that time. Scanned into unit and found no reason for the pcm to take away injector pulse so I replaced the pcm and same issue. I figured timing sesnor controlled the injector pulse so I replaced both sensors and while I had the water pump of i replaced the vvt components while i was in there. Read multiple people have luck chaging the maf for this issue so I changed it. Unit still stalls to this day and loses injector pulse on the ground side when it does. Have noticed watching the live data the pcm is request injectors to fire via injector pwm value. I have redone the ground wires at the left bottom of the block knowing this was the ground location for the pcm but still no luck. I am a mechanic by trade but this is having me pull my hair out. If anyone has something to have me check I will gladly im not much of a parts thrower but im about to load the cannon
    • Actually.  Wait.   I just re-read your original post.  Are you talking from INSIDE the truck you have to hit unlock?  Or from the key fob?  I had assumed from the key fob.   IF you are talking the inside unlock button, I assume you are shifting to park and its not unlocking the doors?  If so, that is changed via the settings page in the radio.  Go to SETTINGS, then VEHICLE and then it should be under LOCKS or DOOR LOCKS or something like that.
