2020 -1500 Silverado. Anyone else getting a wind noise around the review mirror/windshield area, once you hit about 40mph? Sounds like the window is cracked, but at that location.. ...annoying.  Dealership said they tested another truck and said it has the same noise. They think it’s coming from the antenna on top, but no repairs yet.
I remember reading that someone had their OnStar antenna was lose according to the dealership (discovered when replacing the headliner from leaking rear window I believe). That could be what this is from?
I notice slight wind noise from rear spoiler over 65 mph, but nothing out of ordinary from front. I have driven my 19 then 20 and probably 12 service loaners never noticed any noise from front rearview mirror area.
If it is a bad seal try covering seams up with some blue painters tape and see if noise goes away
Sent from my Pixel 4 using Tapatalk
I don’t believe so. The antenna is over the driver side. The noise I’m hearing is right about the review mirror area. Almost seems like it’s the way the wind is deflecting off the hood and hitting the windshield. I’ve never heard it that area before on any vehicles I’ve driven. I’ll see if I can take a good video and post it.
Yes I just noticed this yesterday, not just bc I was driving 40 mph, but was driving while its was a little windy, not really sure what was causing this but definitely annoying.
Mine is constant. Wind or not.  Does yours sound like a window is cracked, but its coming from the windshield/review mirror area?
Edited by Beta
I will have to try that. But I don't think its a bad seal, as nothing leaks.
I have a wind noise in my truck coming from the passenger side rear door area. I have a hearing issue and cannot discriminate noise/sounds well. I actually had a girl that waited for me ride with me for about 10 miles and help me find the noise and make sure I wasn’t crazy(because the dealership told me they couldn’t hear it at all). Mine started after the dealership did the first window leak caulk job and performed the seatbelt tensioner recall. Now I have a noise that would drive me crazy if I actually had access to my truck to drive it(see the window leak thread for more details-44 days no without my truck).
No the other day sounded like howling wind in an old house.
Mine now seems to be more frequent, im calling the dealership in the morning, total bs.
Try turning on and off the recirculation for the climate control. Mine has a wind noise that I can make go away with the climate control settings
Mine is constant as well we think coming from the Front part of the rear passenger window. If I ever get my truck back Ill get my ultrasonic leak detector and find it that way.
    • True. My statement needs qualification. "For a shade tree mechanic, re-assembling the front engine to achieve a rough baseline timing of 0 degrees, as is approximated and indicated by common visual indicator mark alignment, measured with a human eye capable of 20/20 vision *with correction, I am reasonably confident that I have followed the outlined procedures/ prescribed methods for verifying baseline timing."   😉   In the end, the computer sets the timing, it's continuously variable based on sensor input, and the distributor only has a degree or two of physical adjustability intended for dialing in the final setting for cam ****** once everything is back together. But even that final value is acceptable within, I believe, +/- 3 degrees.   I thought my exhaust project was going to be a bear. To my surprise, the old clamps came right off last night, and I was able to unbolt all the hangers instead of having to muscle the rubber mounts. The old cat is ready to slip off the factory y-pipe. The rest is ready to come out with one or two cuts, and I've got a fresh blade waiting. I love living where rust isn't a thing.
    • I work at a Chevrolet dealership & hear it all believe me.  Just reads like there's going to be a fist fight over filters.  Can't get enough, continue!!
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
