Can someone explain to me the plug configuration on this. I thought I should have the standard 7 and 4 pin hookups but have these 2 top cylinder type plugs. The 7 pin is there but no 4 pin flat wire option. The dealer told me it has something to do with a HD camera upgrade, but didn't know much more than that and can't find anything in owners manual.
Looks like you will need to get a 7 to 4 pin adapter like on the older trucks. I guess the trailer camera takes away the 4 pin. Can't have it all!
Did you even read through the owners manual.  It took me less than 5 minutes to find it in the owners manual.  Hint:  It's in the Driving and Operating/Trailer Towing section (at least in the 2020 manual, probably the same in the 2019 one).
It might seem like you know all the stuff GM would put in their owners manual, but you probably don't.  Try reading the whole thing.
3 hours ago, Bill Fielding said:
I did read through my manual and it is not there, you assumed something.... you know what they say about people who assume!
Maybe read more of it?  It has 3 pages on just the trailer electrical connections, pictures of the various plugs, when to plug and unplug them.  It even explains why you don't have a 4-way plug.
It even has a table of contents and an index to make finding specific things easier.
Edited by txab
Ok. Everyone take a breath, and let it go.
Manuals change from one year to the next. OP doesn't state what year he has. 2020 manual does address this. Prior years may not
Quote
If equipped, trailering camera connectors are available in the bumper trailer receptacle in place of the four pin connector. The inside trailer auxiliary camera should be installed on the top left hand   side (A) and the rear trailer auxiliary camera (B) should be installed on the top right hand side.If equipped with the fifth wheel/gooseneck trailer package, the harness connector is mounted on the inside of the pickup bed behind the rear wheel.
Edited by txab
  • 4 years later...
my 2020 sierra (denali) trailer plug receiver seems faulty... the brake and turn signals work, no side lights. DIC says pin # 4 (sidelights) and # 5 are not working. The trailer has no electric brakes, so that makes sense... when I plug in the boat trailer, the side lights will light up for 1-3 seconds, then go off.  Has GM has issues with these receivers?  corrosion? Also the security flash on the tail lights used to flash about every 30 seconds... not there seems to be no pattern of duration, but constantly studder/flash more random.. is the receiver corroded?
UPDATE: plugged the trailer into a neighbor's GMC (2018) and all lights stayed on. One left side light was out, the other 3 were on. I ticked the LED sidelight and it came on... all light functions performed correctly. Then plugged into my truck and all side lights lit up... I think the 2020 connector/software on my truck "sensed" a sidelight was out and then just shut down # 4 pin. The older truck didn't shut down #4 pin.  All is ok now,,, I just wonder what the actual software is in that plug or operating system?
Edited by billybob denali
Full system code scan is step one. All 4 code families, so you can see what all the onboard modules are reporting.
Without a full scan first its a guessing game with todays computers on tires. It's what every shop does.
    • I am experiecing the same issue, I have gone in the setting and disabled rain sensing function but I am still experiencing this. Whe i use my turn signal they will redomly turn on. Sometime they stay on and others times we swipe 2 or 3 times and stop. Its super anoying, escpecially after a fresh wash. Anyone have any advice? . rain-sensing function, but I am still experiencing this issue Sometimes they stay on, and other times we swipe 2 or 3 times and stop.It's super annoying, especially after a fresh wash.When I use my turn signal, they will randomly turn on. I am experiencing the same issue. I have gone into the settings and disabled the rain sensing function, but I am still experiencing this.
    • If we actually used any significant amount of that source in the USA then I'd agree but we don't. We've had that discussion before. We drill and pump more than we use. Thing is, we sell. We export. Gas and Crude. It's more profitable so any shortage here is self inflicted and LEGAL.    I worked a gas plant that has multiple fuel sources available and I worked in the furnace and boiler plant in that facility. I'd had days we swapped fuel types four times in a twelve hour shift which isn't done on supply but on margin. Two of the fuel sources are internally generated. Tail gas and DAK, both of which are sold as well a consumed. We always had more than we needed to run the process but we chose the fuel that produced the best margin not bought at the cheapest price always. A good bit of math to that and back in the time that was done on a slide rule.     I worked the Shale Oil Semiworks of Chevron Research and CONOCO Research in Salt Lake City. That process never went into production although it was very successful. Why? Did we lack oil bearing shale? Nope. Price of crude never made the margins work. That was in the late 70's early 80's. Remember history? What was happening then was a reaction to that situation. It didn't drive it. If so then it's easy. This isn't a supply and demand thing. This is a profit and margin thing and AI rules that now.    In no refining situation that I was ever in would a bomb hitting a well anywhere in the world 'instantly' interrupt or even distress the supply. Most plants have more than a months worth of crude in the tank field and more in pumping stations. That yo-yo could play out over days, weeks and maybe months and have zero impact on plant operations. How many times has this been off and on in the last few months? These people and not stupid. These plants measure down time in hundreds of thousands of dollars per day. They are not sucking fumes or waiting on the next truckload with baited breath. Besides, as I noted, they are for the most part 'vertically integrated'. They own it from the dirt is sits in to the delivery rack and sometimes to the pump. It has a HUGE shock absorber built in. When production suffers, refining wins and when refining is winning exploration is killing. The rest of that crap in the news is a 'news cycle'. Government dipping in to reserves? Oil is stealing their milk money. There's a reason Chevron abandon Venezuela infrastructure and it had nothing to do with security of US citizens. Nationals run those plants. it has to do with MARGINS disappearing to corruption. They are in no hurry to return. Is there supply there? Oh yea. More than enough to offset what is bought in the middle east. Just isn't ???? Profitable.    We have supply. There are places in Illinois you can drive a pipe into the ground and run your homes natural gas furnace on it.    A refinery fire will gum up the supply works but not a localized war where the market is using a limited supply from. Now Europe, that's something other....
    • $4.00 a gallon here now.   Diesel nearly $5.00 again.
    • If we're talking futures, yes, it's speculation.   The spot price of a delivered barrel is elevated now compared to before the conflict. And that is related more to current supply/demand.
    • SPECULATION on the wars effect raised prices. AI is maximizing the profit. Refining is vertically integrated.
