Hello,
New member. I recently purchased a 2020 Silverado 1500 crew cab and want to mount an emergency Light-Bar to my BackRack. I am a volunteer firemen so this will be for a personal vehicle setup so I want to avoid any major changes to the truck like drilling a hole through the roof. I was thinking of possibly routing the wire to the front of the vehicle then through the firewall grommet but that seems like a waste of wire... since I want it to terminate under the back seats. I believe I have seen in the past others talking about routing the wire through the floor of the cab through an existing drain plug with a weatherproof grommet. Does anyone have any advice as to the locations of them or pictures/ links to any other posts about the topic? Does anyone know if they are also under the rear seats in addition to the front?
Thanks!
Hello,
Thanks!
Yes there are some in front of rear seat , look under the  rear of the cab and you see the plastic plug .you can also lift the door still and carpet and run your wire thru  it and don't forget some sealer . I did this on my 2019 LD . Power & Antenna cable .
Thank you very much for the helpful feedback! Also thanks for the tip on the door sill channels. I plan on having my "controller box" mounted under the rear seats. So I was going to run my power through the firewall grommet, through those sill channels and to the rear seat where I can tie in with the Light-Bar wire from the plastic plug. I probably won't get around to doing this for a bit but I will try and document what I do.
My Power wires ran from second battery along the frame with the truck wire hardness  to the plastic plug ,  then under rear seat for radio main unit , control panel , ect. . There's more room under the truck , then the still channel  .  my power wire was tie strap to the truck main hardness every 8" all the way back - BUT that's me.
If you want quick easily reversible and no drilling it can be done it you have a 110v outlet in the bed.all it takes is a 12 volt DC transformer plugged into the outlet and it can be controlled with the power switch in the cluster below the HVAC controls....switch even has a light to indicate when the outlet is being powered. I'm powering the lights on the sports bar that way.....suitable transformer and outlet can provide up to 250 watts at 12v.
Thanks that’s a great idea, never thought about using it. I’ll add that to my list of options to consider. Even if I don’t use it for my light bar it might be a great way to wire in some additional work lights/ bed lights on the back rack.
  • 1 year later...
Not to resurrect an old post, but can you share some details about how you mounted the second battery to the Frame? I haven't found an elegant solution yet.
    • Yea that's pretty normal to be off a few degrees.  Usually 2-4 degrees from say a weather app or thermometer.
    • I just replaced the ambient air temperature sensor.  Easy as pie. I simply had to remove about 10-12 clips on the plastic cover over the radiator and remove two T-10 torx screws on the hood release lever to liberate the cover (Amazingly, none of the clips broke.  All came out and went back in with zero problems). Once the cover was removed, the temp sensor is easily accessible. The sensor cable snakes through a few guides and can be pulled out for even easier access to the sensor. I was able to work the sensor out of the mounting hole.  There is a red sliding catch on the plug that must be pulled back to disconnect the cable.  The plug was quite tight.  I had to use a screwdriver to pry it out. I plugged in the new sensor ($6.45 from RockAuto), snapped it into the mounting hole and re-snaked the cable. I put the radiator cover back on and reattached the lever arm to the hood release.  All done!     I started up my Suburban.  The temperature read 82 °F. Other thermometers at my house read 80 °F.  Close enough.  It might be reading high as my vehicle was sitting in the sun.
    • Remember when you were 50 and they called you Old Man?
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
    • I'm thankful to live where we don't have extreme weather. We might all be blown to smithereens when Mt. Rainier goes, but 80 is warm enough in the summer and I can generally count the number of hard freezes in the winter on one hand. The cars here don't rust and they don't get sun-baked, either.   We have finished off many of our average 52 days of "clear/sunny" weather, though. Sunsets are coming earlier, the nights are a little cooler. It's right around the first week of September when we get our first warning that summer is coming to a close with overcast skies and the start of "hoodie weather" temperatures during the cooler parts of the day. By October, it's usually time to ditch the shorts. By November, it's mostly raining.
