I know.  I know.  My 81 year old father in law wants to order a new AT4 because of the way it looks but has a hard time climbing in and out.  The truck will be on the highway 99.999% of the time and if it ever is off the pavement, it will be a gravel road.  I tried to talk him into the Denali but he hates the chrome and the cost of the AT4 parts to make the swap are stupid expensive.  Does anyone know how GM achieves the 2" lift and can it be reversed?
Curious of this myself. And im the same as your father, hate chrome, love the look of the at4. Due to a back injury from the military, there are days that getting in and out are a challange.
I think basically it is different shocks/struts, blocks, and front axles. You could easily remove the rear block and change the shocks. Not sure on the impact of the front axles with lowering.
GM also offers a 2" lift kit thru accessories.
Have a look at the kit --- it will show what is changed.
Has he looked at an Elevation in a colour he likes?  Might be a lot easier than removing a lift.
Maybe a Denali and change the grill and/or grill surround or an SLT and vinyl wrap the chrome bumper?
Thanks.  I looked at swapping all of the various trim pieces and the cost was astronomical.  Best estimate from the body shop I trust was over $6500 parts and labor.  I can't imagine the cost of the lift kit installed will be more than half that.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 472 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
