2003 Chevy Silverado belt squeaking
Looking for some help identifying the squeaking going on while the truck is running. I’ve changed out the belt, idler pulley, and tensioner pulley as well. Still squeaking. Squeaks the whole time I’m driving and gets louder when hitting the gas. Makes me want to pull my hair out. Have had someone mention the water pump to me but not real sure, any help appreciated.
I always check belt related squeaks with a spray bottle filled with water. Adjust the bottle to a pinpoint spray and shoot it directly on the belt before the belt hits each pulley. If the noise goes away then you are having an alignment problem with your belt on that pulley. If the noise gets louder then your tensioner has failed and is allowing the belt to slack too much and is slipping on the pulley. More than likely it's your tensioner so long as you never touched any of the pulleys or removed and reinstalled any of the belt driven components.
Could be any of the bearings on the components driven by the belt...alternator, water pump, AC compressor, etc
kickass audio, I had the tensioner And the belt replaced 2 weeks ago and I replaced the idler pulley yesterday. I replaced idler pulley because I did the spray bottle trick, sprayed directly onto the idler and the noise stopped for just a second
Remove your a/c belt and ac belt tensioner. Buy a 2010+ a/c stretch belt from GM and install it. We do this a lot at the dealer. You will never have this issue again.
Hope this helps.
-Friendly neighborhood GM tech
