Installing dirt king long travel shackles, currently have the deaver mini-pack and rear block removed. Next will project will be replacing the bilstein 5100s!
Edited by mcglothlintoby
Changed text
that’s cool, haven’t heard of those before.  What kind of drop do you get with those?
and you’re replacing the 5100’s with what? And how come?
I too am looking into doing a rear drop with shackles and more than likely replacing the OEM Ranchos.   Hoping 3” drop levels me out in the front to back.  The lowering thread is like 200 pages long. Still got like 80 pages to go
They are an offroad racing company, Iowa's expecting a 1/2" to 3/4" drop but it seems to be the same ride height. These are designed for my suspension travel. Run about $180 bucks for the pair.
Got finished up after a lunch break, very smooth ride and about a 1/2" lower in the rear. Rear still measures a 1/2" higher than the front.
nice   Seems those have more function then the usual drop shackle for just the look
41 minutes ago, rbrjr1 said:
what do shackles do? (im not a car guy)..
They attach your leaf springs to the frame, coming in different sizes, so you can raise or lower the rear of the truck.
Main function is they articulate back and forth, and up and down so the spring pack can move freely without being fixed to the frame.
The yellow part in the video is the shackle.
Edited by JimCost2014
Just got 2.5 Kings and dirt king UCA's for my truck. Been contemplating what to do on the rear. What shocks are you running?
Sent from my iPad using Tapatalk Pro
Just Bilstein 5100s still
  • 1 year later...
did you notice any difference in ride quality with just the shackles installed?
    • Ahh, sorry about that - I got some bad info. Newdude is correct. That's what I get for working 13 hours straight ... on my "vacation", lol.   Should've checked the files I had instead of the internet.   Anyway ... this is GREAT news, since this would've been an absolute friggin nightmare to get working.   I don't think the lack of VVT is causing this - you've got another issue. Wiring, I'm betting.   I'm telling you right now, your computer isn't bad. If it worked before the swap, it's working now. You need to do some more (better) diagnostics and figure out exactly what you're missing. Did you test every wire directly at the MAF? Have 5V reference? Ground? If you're reading ZERO g/s, your Hz isn't much use - it's going to be the wrong value anyway. The MAF is not working, and you need to find out WHY.   I got this off the net, so VERIFY first: Pin A: Black (BLK) wire, Circuit 552, serves as the Sensor Return (Ground).  Pin B: Tan (TAN) wire, Circuit 472, carries the Intake Air Temperature (IAT) signal.  Pin C: Yellow (YEL) wire, Circuit 492, is the primary MAF Sensor Signal output to the PCM. Pin D: Pink (PNK) wire, Circuit 339 or 539, provides Ignition 1 Voltage (Power).  Pin E: Tan/Black wire, Circuit 552 or similar, often associated with the Intake Air Temperature ground or signal return.  Global-A list: https://postimg.cc/KKJnQC85
    • Correct....the end user can't reach to Realtruck directly like they can if they purchase a Bak, Undercover, etc...  It has to go through a dealer.
    • It is 4wd. shop told me it is the slip yoke. But not sure.
    • No, I did not tune out vvt. From what I read it should still be able to run without it, it'll just lose some torque/power.    I can see how that would make it not run correctly, but why would that cause the faulty MAF readings?   EDIT: I just ran a quick test and checked, and as I expected, the computer sees that the VVT cam phaser solenoid is not present, and throws a code for it, and does not try to change the cam angle at all. Commanded position just remains at zero, 100% of the time. This makes me think that the VVT is most likely not the cause of the problem though if anyone has a different/better explanation, I'm all ears.   UPDATE: I was able to find that my scan tool does indeed support reading the frequency (hz) off of the MAF (I thought it wasn't supported but turns out I just didn't know where to look for it). I noticed that regardless of engine state it always however this Is not what I observed with my multimeter. Like I said before, the MAF seems to put out a normal signal during cranking and then the signal drops to a very erratic reading once the engine is running. It seems from what my scan tool is telling me that the ECM is not recognizing this at all, and just reads 0 Hz 100% of the time. This pushes me towards the the PCM itself is faulty. I I have the PCM out of the 2007 donor vehicle, which I may try to connect and program (it's only ~50 bucks to get the software for a one-time programming)
    • Did you tune out the VVT?  07-09 they did not have VVT.  2010-2013 they did.      If you haven't tuned it, its trying to adjust cam timing.
