AC Delco Ultragaurd Gold
flyingfool
3 hours ago, BigBlueLB756 said:
  Sometimes, new and improved sucks.
Funny thing to say. We live in a world of dumbed down to ridiculous. When is the last time you saw a new mahogany boat? Plaster and lathe? Asphalt shingles? The inside of a truck not made of leather grained plastic? Did cows all the sudden stop dying?  How good does a throw away part need to be? It does it's job. How does that suck? Just asking.
  • Replies 36
Sorry, Oh Exalted One.  Sometimes, some of me is not willing to accept the "cheap" when something of more quality is still available.
At 75, I guess I'm just a fuddy-duddy, stuck in the past with old way thinking.
Hey George don't misunderstand me. I'm right there with you. I use a Purolator now. In fact I use the PBL22500 BOSS (black). The (red) L22500 and the PF63E filter about the same and cost the same. The Purolator is just better built. All I'm trying to say is that it is the AC Delco PF63E still perfectly capable of doing it's job for 5K as built and no one should worry about it failing.
Further if you want the better built filter and are a diehard AC Delco follower use the UPF63R BUT if you decide to do that then be aware that it filters no better than the PF63E. It's an upgrade in construction only. AND you could be using the Purolator PL22500 Blue filter for the same money with a HUGE increase in filtration.
If you really like throwing money away use the Mobil 1 M1-212A. Cost more than the BOSS and filters about like the Red. It will just do it longer. GM isn't alone in the smoke and mirrors game.
FYI, only one is "Highly Exalted", God. Please, not even in jest.
My sincerest apology.  In no way did I mean to equivocate you with the Lord Almighty.  Only meant to show reverence to your standing in the forum.  Sorry for the mistake.
    jaszr2
    jaszr2
  • Who's Online   6 Members, 0 Anonymous, 528 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
