I couldn’t find this in the search... But I know it’s out there.
One thing I would love to add is OEM looking overhead grab handles above each door (front, rear, driver, passenger). Multiple times I’ve had passengers instinctually reach up there Only to find nothing. The grab handles that are in place are great but I’d like to add additional ones up on the ceiling like they’ve had in the past.
Anyone do this? How much work would it be? It’s obviously got to be mounted sturdy so people don’t rip it off!
cheers.
That's the only thing my wife gripes about too!
I looked online trying to find something but nothing looked good. I plan to keep on looking and hopefully find something that can be mounted.
  • 11 months later...
I too struggled to find ANYTHING on adding ceiling/roof area mounted grab handles. However,  I currently am 90% complete with the installation of a passenger side grab handle for the wife. What I have discovered is there are two mounting bolts for the air bag located in the exact location for the handle!
Removal of the weather stripping from the A pillar to the door handle side is necessary. This is very easy and reinstalls easily also. I removed one bolt above the seat belt (marked air bag. It is not for the airbag) this bolt allows more access for you to pull the edges of the headliner down so you can see the two brackets & bolts that support the airbag. These 2 bolts are the exact position and distance apart for my grab handle. Now, the tricky part!
In order to get the handle in place "two" "slits" will be required...I am going to cut a "T" shaped "slit" into the headliner....This will allow me to slide the mounting ends of the handle through the headliner and attach it to the "bolts" used to mount & hold the airbag.  I'm using the "T" cut, instead of a straight line cut, so I'll be able to slide the 10mm socket over the bolt head from below. (*These 2 bolts where loosened by prying the headliner down just enough & with a mirror & swivel socket adapter,  I was able to un-screw them enough to remove them. Note, they have a guide pin also that the circular bracket holds in place. It comes out easily too...)
The "T" slit is necessary & will be the only issue & potentially require some cosmetic surgery.  But the benefits will totally outweigh the minor cuts. Just to keep the Wife happy!!!
Check back today or soon,  for the final outcome and pictures.
  • 3 weeks later...
  • 5 months later...
How or do you think this will effect the side airbag system?
Would love to have the handles if I'm not mistaken my buddy's 2018 has them.
Edited by WeGone
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
