Recently bought 2019 Silverado lt trailboss with 5.3 and 8spd tranny
What's the normal operating temp for 8speed transmission? Not towing but just driving in the city/hwy. I'm getting between 70-85 deg Celsius or 158-185 deg f.
Also noticed temp went really high while driving in the moderately deep snow on the back road in 4hi. 140deg Celsius! Which I think is 290f.
Are these temps normal?
Coming off dodge  with 5spd tranny it was running at 50 for normal use and Max of 80deg Celsius these high temps are new to me, unsure if it's even normal?
Truck only has 1300km
Edited by Giantpeaches
That sounds high. At 285F you are close to burning the fluid although, the gauge/sensor may be inaccurate, I would get it back to the dealer.
That doesn't sound right.  If it truly was that high something is wrong.  I would think it would have thrown a code.  How long of a drive in the deep snow?
Yeah.. I figured it would throw a code but it was definitely 145deg C. I should've taken some pictures at the time but didn't think to.
I'd say about 1-2km/ 1.2 miles? till I decided to turn around and go back.
not sure if tech can plug in obd reader and pull some historical data or anything..
Meant to drop it off tomorrow to have couple of things looked at.
At 290f you cooked all your fluid and probably want  a new trans. Probably a sensor issue. let it sit all night and check the temp in the morning, it should be within 10 degrees of the outside temp.(actual temp not the trucks outside temp).
What does the fluid look like?  At that temp like posted above I would think it would have effected the color and no longer be a nice pink color.
since then it's been running normally. I don't exactly know what the normal temperature for city/hwy driving is for these trucks and tranny but I find it runs between 140-180F
Is there way to check fluid color on these 8 spd transmission? I just know there's no dipstick to check the level or anything
There is an inspection port so to speak on the side basically where a dipstick tube would go.  There is a plug over it.  Could pull the plug to check.
Just heard back from the dealer and they couldn't pull any codes or parameters all seem normal and he assured me 140-180 is normal operating temperature.. I asked in Celsius or Fahrenheit? and he said celsius.. seems wrong....
  • 2 years later...
To check trans temp, scroll through drivers info steering wheel, there is one blank screen before the trans temp screen. My truck has a trans oil cooler, I think, and you would think the trans temp would be cooler than 180 degrees F, with an ambient temperature of 40-50 degrees F, and an unloaded truck.
I definitely have a transmission oil cooler but it doesn't seem to change my temps. I don't think anything is going to keep them lower considering they have a thermostat that keeps them pretty warm. I could be wrong though lol.
    • Mine worked fine until I got an update also. After that sometimes it would not connect and Id have to turn CarPlay off and then back on for it to try to connect again. I think I have had two additional updates since this started and it has gotten better but still not perfect.
    • It’s probably water in the doors. Mine had tape over the drain holes! Poked them open and that took care of it. Now I’m waiting for the rust to come through!🤬
    • Hi all,   I just bought a 2021 suburban RST with 88,000 miles on it and everything has been good but I’ve been noticing within the last month or so that there are small electrical things going on and I know what the AGM batteries and all the electric electrical in these big trucks you need to have a constant flow with good voltage   That being said, I bought a new battery thinking that that might have something to do with it but today I went to get in and start it and it said no key found when I had the key right in my pocket   It also proceeded to flash the lights inside and outside for over 30 minutes as I went to disconnect the battery as soon as I touch the negative terminal, I heard the relay reset and everything come back up. I got in the truck and started it no problem.   Anyone else have this happen to them? I’m starting to think it’s the KARR system that the dealer installed short circuit stuff.
    • I don't drive this truck on a regular basis since I have a new company truck with no out of pocket fuel or maintenance cost. Yesterday I got it out to run some errands and got the title message on my DCI. A quick Google search suggested to first clean the Map Sensor. I pulled it out and it was sooty so cleaned it up and reinstalled it. Issue not resolved. My OBDII is a couple years old so didn't see any codes. Today I took it to a friend at AutoZone to get him to check it with his reader. It had the following codes: P20C3 P02BB P221F Stating the most likely solution is to replace diesel emission fluid (DEF) tank assembly.   So, I guess a trip to the dealer is necessary. I read where there was a backorder on these tank assemblies several years ago so hope that has been resolved.
    • Are you using a weight distribution hitch system with your trailer as that alone can change the actual tire pressure requirements needed. It would prove interesting to see what the actual individual axle weights are on your truck when you are hooked up to the trailer. In fact when your hooked to the trailer, typically if anything unless it has a large capacity weight distribution system that is over cranked, often the weight on the front axle will be less when hooked up vs driving empty and certainly if one doesn't have a weight distribution hitch. Really the only times one may get up there with weight on the steer axle is if there was a snow plow mounted on the front or a motorcycle on a rack or with a very large jockey tank full of fuel at the front of the box that transfers a bit of its weight to the front axle.    And of course your tires carry more weight for a given tire pressure due to their size vs a stock sized tire so there is that to take into the equation as well.
