Wiper problem
So the wipers on my truck don’t work I have replaced the switch in the steering wheel the motor and module and I am getting power to connector so why will my wipers not come on at all
get a test light and check all the wires going to motor with the switch ion  high low , and all delays, then put test light clamp on positive side of battery terminal and check the ground wire, not sure how many wires you have on your motor , but im guessing about 4 , 3 hot and one ground, check for hot first , and then the one that doesnt light up should be ground , reverse battery connections and see if the lone wire lights up.
i have a subscription to alldata , , its an online repair manual it shows connector on wiper motor and also which wires do what, it might help you figure this out , not expensive ether i paid 50.00 for five years one vehicle , but you can get it cheaper for less time subscription
  • 2 months later...
Kinda having the same issue but mine arent quite to the point yours are... Sometimes mine will be working, ill hit a bump, they stop working til i find another bump.... makes me picture a stripped out actuator (or whatever makes the wipers rotate) Could be the case with yours?? Just a thought anyways, that reminds me i need to fix that..
My 93 Silvy 5.7 had intermittent wipers.
Slow to fast setting.
They started working when they wanted.
Wiper motor pulse board fixed it.
Back then a dealer only item $125
It started working when it wanted after so many years.
Got another one at Orielys cheap.
Here on Rock Auto
https://www.rockauto.com/en/catalog/chevrolet,1993,c1500+pickup,5.7l+v8,1031331,wiper+&+washer,wiper+motor+pulse+board+module,8865
$27
    Patrick Fergy
    Patrick Fergy
  • Who's Online   2 Members, 0 Anonymous, 1,271 Guests (See full list)
