When are you planning on doing it? WE NEED TO KNOW!!!!!!!!!!!!!!!! [emoji3]
I have some hay I need to mow, rake and bale first...but if it rains, I'll pull it into the shop and work on it!
stand pipe is part of the re-fill proceedure on the camaro. I would just zip it off with a dremel tool, unless its used to suppor the camaro trans filter, then i would leave it and drill a few drain holes around it's base
you did order the taller camaro filter right?
Edited by flyingfool
  • Haha 1
Oh, just one more thing! About that filter.......(Columbo) :)
I thought the same thing, cut that stand pipe off. Just be sure there are still some threads left in the bung.
So how do you get the fluid out of the lower part of the pan? Just asking. (That plug isn't really a 'drain')
That was my first thought when I unboxed it as well. Technically, it is a drain plug. But not one that will allow you to drain the pan completely due to its location. I'm considering just getting a weld on drain plug and having my buddy at the local welding shop put it in at the lower end of the pan so it'll remove as much of the oil as possible.
The top of that stand pipe is the FULL level.
Standard pan. Wasn't too sure I wanted to try a deep pan or if it would fit.
also wondering if there is a rubber gasket behind that drain bolt from GM.?
i would of ordered the deep pan instead.. anyways I look forward to seeing what you come up with.
deep pan is more for heat resistance capacity, not for ease of draining.... but I just disconnect the upper trans cooler line , and pump the fluid from this line  into a bucket, then pull pan and filter.  if your hard core, you'll drill and tap the torque converter for a pipe plug for more drainage
Get a might vac fluid extractor, best thing ever for doing oil changes or fluid exchanges.
I can suck a hot transmission pan "dry" in a few minutes. I've done the last 3 oil changes on some of the family cars in the garage without even taking the drain plug out.
Which model/version did you get?
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,121 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
