Nice. Looks like it should be 13.6/7 for a 1/4 mile as long as the governor doesn't hurt you. Surprised i have not seen any performance threads on these new 6.2 trucks. I have been wondering what kind of time they would put down.
Wasnt sure which tire set up you had. Some have tires rated lower and so the governor is only 98 mph. Mine goes to 114 too.
19 minutes ago, f8l vnm said:
Yep mine is also 102 for my 2019 with 22s
Look like they all over the place with the shut off, I have 22's also.
Edited by Red highcountry
It all depends on the tire speed rating that truck was born with.
tow haul mode with no brake torque,put trans in manual mode into second then you shift it, spare was removed, ran 8.72 with spare tire.Have you ran your at track yet just trying to compare mines.
I would love to see this thread blow up with 6.2 times. I should go run mine.
I assume this is a top gear limiter like in other vehicles?  In other words, 112 mph in 10th gear.  So you could downshift and go faster (at least that is how it worked in the 5th Gen Camaros).  Thus it also wouldn't affect 1/4 mile.
Edited by Jim E
That is interesting. I have never heard off that. I kinda doubt it because anytime i have hit a limiter it has not been in top gear. Its restricted based on tire ratings so i don't think the gear has any role in the limiter. On a camaro that could he completely different since the tires are probably rated for more than the car will do.
Edited by smrr1
    Frank V
    Frank V
  • Who's Online   5 Members, 0 Anonymous, 1,346 Guests (See full list)
