I have a 2014 Chevy Silverado. My driver side window works fine. My passenger side window only works for the passenger side switch. My rear windows do not work at all. I replaced the switch and have the same problem. Any ideas I’m at a loss?
Double check the "Child Safety Switch" for the windows to make sure that it's not set.
Check fuses, and ohm wires from switches to window motor.
Check the wires in the door jamb for breaks. Try grabbing the rubber boots and moving it around while operating the switches to see if they start working.
1. Test the driver's window switch power and ground feeds.
2. Check for wire breaks in the door jamb boot.
3. If there is low/no voltage on the Yellow wire in terminal 43 at the switch, cut the Yellow wire in terminal 22 in the X2 connector at the Body Control Module (BCM).
4. Confirm there are 12 volts on the Yellow wire on the BCM side of the cut.
5. If there are 12 volts, check for an open in the Yellow wire between the BCM and the driver power window switch.
Sent from my SM-G988U using Tapatalk
You're welcome. I see that all the time at work. Probably best to add enough wire so your splices aren't in the bend.
  • 2 years later...
Thanks for posting this topic. I had the exact same symptoms. I thought it was the switch also. Them I found this site. Found the same broken wires in the door jam harness.  Very helpful.  Thank you very much.
  • 7 months later...
I have the same symptoms, but my wire harness looks good, except the thick black wire is cut and exposed some. Ordering a new harness now, hoping to have positive results.
Yup, this.
On 3/14/2020 at 8:46 AM, NE18 said:
Is this a common problem on the K2’s?
I know this post is from 2020 but when my 2018 was in the shop in July for this, the GM dealer said it was becoming more increasingly common.  As well as the hood sensor/switch failing.
So it ends up that while I found a slice in the black ground wire in the main door harness, I actually only needed to replace fuse #8 in the drivers side fuse panel to get everything working again. Thanks.
I have a 2018 Silverado. The passenger window will not roll down from the passenger door switch or the drivers door switch. All of the other windows work from their respective switch and the drivers panel. I replaced the switch and the window motor assembly (both OEM) but the problem remains. Additionally, the door ajar light is on continuously. I checked the fuses and the wiring and I can’t find any issues. Any advice?
Edited by Derek D
Adding info
Have you run a scan with a scan tool?
Also, have you checked all grounds (yeah, I know, always the easy answer without solving the problem)
Still, a scan would probably find the fault, might be a legacy code that needs a reset.
  • 3 months later...
 I have a early model 2014 Chevy Silverado and the drivers side windows have stopped working as well as the stereo stays on after the vehicle is shut off (opening door does not cancel the radio) I have replaced the window switch, door wiring harness, and the latch on the drivers door. I have also checked all fuses and they are good any ideas where to look next.
  • 5 months later...
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
