Recommendations on upper control arm and lower ball joints
Working on my suspension for my 2014 Silverado I just purchased some benstein shocks 5100s and I need to replace my upper control arm including lower Ball joint I’m looking for recommendations I’ve herd good things about Moog products but wanted to get some onsite if Detroit Axel is any good seeming they are very inexpensive
Moog has rested on their laurels in my opinion, and their quality has suffered for it. Our local Auto Value stores (all of them in fact) got rid of all Federal-Mogul products a few years ago (including Moog) in favor of other parts brands. The suspension components they now carry are made by Mevotech, which I've compared side by side to a few Moog pieces and the quality difference is apparent. Also, there was a tool/ parts expo recently that I attended and I stopped by the Mevotech booth that had various ball joints with cutaways (including Moog) and the differences were great: larger ball and sockets, metal bushings/ bearings instead of plastic, and encapsulated dust boots instead of slip fit. The representative informed me that their TTX line (heavy duty/ premium essentially for trucks/ SUVS) carry a lifetime warranty. Related to that, they had a upper control arm for either GMT800-900 and I picked it up and almost dropped it. It was like 15 lbs of what I was shocked to find was (as he told me) forged steel; not cast iron like I suspected. This was a replacement for the factory stamped steel arms.
Not saying Mevotech is the be all, end all, but since it's the best available locally for me, it's what I've been using. Also, Detroit Axle, despite the name, is Chinese junk hence the price. A friend went that route with some wheel bearings and CV shafts and had repeated failures within a year before he wised up and just bought better parts. Best of luck with whatever you decide!
3 hours ago, carkhz316 said:
I appreciate the feed back I’m going to get going on this project will post some pics and let y’all know how this goes.
After doing some research in my option I feel that replacing the bushings on the existing control arms and replacing all 4 ball joints Upper and lowered the some high quality ball joints  would be most cost effective with still getting the job done correct What do you think about not replacing the top and bottom control arms but updating the bushings and replacing the ball joints I’m also going to be installing my benstien 5100 in the front and rear.
It's just easier for the driveway mechanic to do, as they generally don't have the tools to do it, and they rent/borrow the tool to do it, it's still not easy to get it in there and lined up to do it if you aren't doing the bottom one at the same time.  And it's faster to do.
When I first got my truck, I found the upper ball joint on one side had completely worn through the top of the housing, and I just replaced the whole UCA, which went faster than doing just the fall joint.  Earlier this year, I replaced all the ball joints and the wheel hubs, and it took longer to get the upper ball joints out, and it was a hassle to get the spindle and brake calipers out of the way to do it.
I don't do as much of this stuff as I use to and since the bailouts it's been any ones guess on quality. There are OEM parts that pass muster. Some don't. If a part just wore out in a reasonable amount of time or miles I tend to stay with the OEM part. That said if it's a problem I've had allot of success with MOOG's Problem Solver line of products. Like almost anyone else companies have multiple lines of products. Some to a price point, some to solve an issue or meet a market demand.
Loaded assemblies, as Dave just pointed out, tend to be easier to swap and take less tooling and knowhow to do but at an increase in cost and sometimes at a sacrifice in quality. My Honda broke a spring last year. Parts guy looked at me like I had three eyes when I ordered the spring. Spring was $50. Loaded strut was $450. Yea, I have access to a strut compressor. I could have gone aftermarket but then I would have needed to replace them all. Sometimes the OEM is just the best solution. Even GM has three lines of parts so be careful if you go this route.
    • Its just that it worked on 2024 trucks on this forum and my 2025 model truck, unless GM did something since that point to screw up access or Autel has a bad update. I haven't had need to use my tool since last year when I did the changes to the placard pressure settings and since then I updated the software on my Autel but have not plugged into the OBD so hard to say if I would get a surprise as well.    All I know last year when I bought the Autel I was warned to be sure to update it before I tried using the unit as they said who knows how long ago unit itself was actually manufactured as the software could be way out of date.
    • And so you had gone through the process of registering and updating the tool and so on ?. All I can say is that on the front page as the tool fires up you go to advanced mode, then vehicle model comes up and you choose Silverado ( not the DRW or EV  since your a single rear wheel ) , then I think its choice 2 which is 07/2021 - 12/2026 ( 433mhz 13542523 ) as that is the series of tpms sensors and then go down to choice 5 which is tire type/pressure selection. Hit yes and it says to connect to OBD port and turn ignition on.    Having said this, I updated the software in my tool lately and these year range choices look different from the past due to them doing some updates it would appear and I have not connected up to the OBD port since last year so hopefully I am not in for a surprise with them screwing up the software and that it won't work on my truck anymore either.    So my question is, when you plugged into the OBD and started your truck it had that message on the Autel screen "vehicle not supported" ?. That does seem odd as tire shops would be pissed right off if hey can't use their tool on the model year after mine that in theory is supposed to be much the same truck ... unless GM did some change in the computer system to block certain things from access.
    • Understanding and using modern scan tools is its own body of knowledge. I had little hope that would work...programming access to the BCM is probably required and that is not easy for us consumers. Expensive scan tool, GM programming subscription, online authentication, etc.   It also may be a matter of finding the right dealer to program it for you. Flashing a modern BCM might be a little too advanced for most tire shops.
    • Update for anyone following:    Installed everything as shown in diagram. Opted for 8 AWG from Battery Positive to a 50A resettable inline breaker. 8 AWG is tied into to 2x 12 AWG wires feeding a 6 way fuse bus in parallel (manufacturer’s design of what I purchased).    4 of the 6 fuses available for circuits are tied to terminal 30 of each relay. I tied a jumper from one of my spare circuits off the bus to terminal 86 of each relay. The trigger, terminal 85, was pulled from my interior by way of T-Taps from the X61A-X5 pins 10, 11, 17 and 23. This was the hardest part of the job. Even with the X61A unbolted and the X5 removed - there was VERY little wiggle room.  I added back up lights that I want to come on with my cargo lamp - but when I would check continuity between S48A-X1 pin 18 to its respective landing point on the X61A-X5 it triggers the factory relay… Instead I opted for a add-a-fuse on the passenger interior fuse panel (fuse location 10 - cargo lamp) and ran it through the boot on the driver side to my load. Did this to avoid introducing any electrical gremlins.   Note: Please check for continuity between the S48A-X1 and the X61A-X5. In my case wire colours were not the same as other’s who have posted. To do a continuity check you need a Multimeter. Completely disassemble the S48A-X1 and remove the brown face plate off the X61A-X5 by way of a flat head screwdriver - this was the only way I could get any results.   The outputs, terminal 87 of the relays, were fed into a junction box and landed at Individual studs and were labelled Aux 1-4.    At this point, all you need to do is run wire to your loads and bring them to ground. I created a negative bus in the engine bay, all my negatives land here.    For anyone having issues with all of your new aux switch lights coming on with the press of one - I noticed this only to be an issue when the battery wasn’t hooked up to my relays? No idea why, but it was quickly corrected by having my system buttoned up and functional.
    • Well I ordered the Autel ts508, and it won't work on my truck I tried all the 2023 and everything it just says vehicle not supported lol   I'm able to send this unit back, so I'm going to do that, then I'll just stop into a some tire shops and if none of them are able to do it, I guess ill have to spend a bunch of money to get a good scanner..... Thanks GM lol
