38 minutes ago, brisk00 said:
I went to tackle this exact project this afternoon but the jack I have (non-gm) couldn't get the tire completely off the ground.  I tried to wedge the springs with a flat head per instructions and they would not budge.  I am assuming I need the tire completely off the ground.  That being said I'll be trying the GM supplied jack tomorrow as I ran out of time today.  So I have a question for you...
Per the Owners Manual it says to use the GM Jack on the axle between the differential and the shock.  Is this what you did?
No!  I put a floor jack on the frame near the rear door and jacked up one side of the truck until most of the weight was off one rear wheel. This mostly unloads the leaf springs and allows the flat head screwdriver technique. Full disclosure, there is still quite a bit of force between the springs. I used a big screwdriver (+/- 2 foot), and had to spit on the rubber (hehe) to slide it in between the springs.
I don't see how jacking on the axle between the differential and the shock would unload the spring.
That's what I was afraid of.  I even doubt that the provided jack would be able to lift the tire off the ground from the frame location you mention.  I'll have to wait.
This exact same thing happened to my 2019 silverado all star,  they changed U joints then eventually changed leaf springs,   fixed the problem for 3 months,  now chunks worse than originally
See my post from April 11th. $40 and 15 minutes and you will have this problem SOLVED!
Same here (2019 3500 SRW).  Braked a bit harder than normal as a light changed quickly. It Sounded and felt like I had a loose keg rolling into the front of the bed/bulkhead.  I looked int eh mirror to see if someone bumped me.  I have bags and prior to this I was running them pretty high due to a heavy trailer (10k triple axle).  However, I did not have the trailer hooked up at the time and bag pressure was lowered.  I assume the springs were bound a bit from the tow and let loose.  Only 32k on the clock.  Pretty disconcerting.
This is certainly not what we like to hear, deminimis.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2019 3500 SRW. To do so, please send an email to [email protected] with ATTN: deminimis/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s privacy policy, please visit https://www.gm.com/privacy-statement.html.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
2022 3500hd,  dealer attempt to solve (more BS then anything) according to tech bulletin (so they claim)returned in oct, new spring packs ordered and came in 7 days later, going to be installed next week
pics are after sept visit
i have had several trucks with leaf springs since 1972 and never had this type of issue
i will add the GM customer service is attempting to help resolve it
I just bought a brand new 2023 LTZ  Z71 Duramax LZ0.  $65,000 truck and the clunking is driving me absolutely insane! Mine happens primarily when I’m entering a driveway, turning in and approaching or coming out of an incline. Sometimes it sounds like I’m getting clunking from the front and the rear. It just spent an entire week at the dealership, no loaner car, they said they used audio mics, and that it was coming from where the driveshaft enters the rear end.  I can’t stand this, and might be trading it.  Please keep this thread alive if anyone comes up with anything. I would love to fix it myself, if I could…
This is certainly not what we like to hear, David Cheney Photography.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2023 Chevrolet LTZ Z71 Duramax. To do so, please send an email to [email protected] with ATTN: David Cheney Photography/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s Privacy Policy, please visit https://www.gm.com/privacy-statement.html. The information you provide may be monitored and recorded and is subject to the GM Privacy Statement.
www.gm.com
www.gm.com
Check my previous posts.It hasn’t made the noise since I fixed it myself.I thought it was coming from the rear differential also but it’s not.It’s the rubber pads in between the leafs chattering transferring the noise into the rear.3M or equivalent makes a spray wax for rust prevention for the inside of doors,fenders,quarter panels etc…It’s not wax for the exterior paint,it’s for rust proofing,which you should have done to your truck anyway even if you live in the south west. Jack the truck so the rear hangs down and spray the body and cavity wax in between the leafs, especially where the the front and rear spring pads touch the springs.You can even pry them apart a little with a pry bar or a wedge that you use when cutting down trees.This wax does not wash out and always stays soft and tacky like beeswax.
1 minute ago, poppy510 said:
I’ve posted my simple solution too…a number of times. But people continue to be perplexed by the noise and how to fix it.
Including the geniuses at General Motors 😂Now let’s talk about the replacing the BCM so the radio turns off when you open the door after shutting the truck off😉Under warranty,they don’t want to do that,but they’ll charge you to do it and fix the problem after warranty is expired 😉I took care of that problem before they could also👍…What about the non responsive throttle and hunting for gear when you NEED to move in a hurry???? I’m almost done with that problem too😉
Don't buy the spring things.  This guy is ripping people off at $60ish shipped for this junk.   I put some in my truck mid Septemeber and had to remove them in early December and replace them with some home made ones that I made with much stronger material.  There was nothing left of 2 of them and they other two had compeltely torn and were about to fall out.  I sent this guy an email from his site and he never responded.   Took me all of 5 minutes to make new ones out of some rubber used at work for boot soles.  These will last a long while.
2024 crew LTZ
same issue.
It’s currently in shop with under 1000 miles on it. Made the head manager ride with me so I wouldn’t get the “can’t mimic sound.”
he heard it several times and said yea it’s not suppose to do that.
    Matt Parker
    Matt Parker
  • Who's Online   3 Members, 0 Anonymous, 878 Guests (See full list)
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
