2002 Silverado 4X4 Regular Cab Z71 5.3
WHAT is this squeaking noise?  Anyone?
Truck has a minor soft low pitch  sometimes intermittent muted  squeaking noise coming from somewhere near the ash tray area - or near the airbag key/light on dash - or someplace nearby.
Yes, have removed ash tray - that's not it.
Could be coming from heater area.
Noise does not fluctuate with heater fan.  Heater fan Off.  Still noise. Heater fan on any speed - noise is the exactly the  same.  No change is pitch or sound on any fan speed.
Turn the engine off - then key in ON position - still squeaking noise.
Hvac? I have a ticking or popping noise that I'm trying to figure out under my dash. ticks and pops weather the fan is on or off. Only does it when i mess with the climate levers heat or cold.
Edited by echobyte
I have a 2002 myself and have been doing a lot of work to it recently.  any chance the sound disapears when the guage/radio trim/bezel is off?
I found it most interesting that GM put a micro bead of rtv like substance around the inside edges of the bezel to eliminate squeaking and vibrations.  I wonder if that's deteriorated or fallen off on your car and is the cause of a squeak that you hear.
Thank you for the answers.  Note that the sound is sporadic.
Sometimes no issues. No squeaking.
Sometimes the sound all day or squeak one trip.
Well.  It's been  a month now.
And no squeak.
Sounds like your noise may be the blend door actuator.
I chased a squeaking sound for more than 10 years on my 2002, that I though was coming from behind the gauges in the dash.  I ripped that thing apart stuffing foam and felt everywhere.  It turned out to be excessive slop in the lower steering column bearing.  Added a worm drive clamp for $.90 and fixed it, per the link below.
https://www.refugeforums.com/threads/chevy-truck-steering-clunking-noise-easy-5-00-fix.1007043/
  • 3 months later...
And no squeak.
Had noise on and off for about 4 months. Last year.
So far, it's been gone for about 6 months.
Well, that dash sound was weird.
I did take truck to local mechanic and he heard the noise.  As if continued I was going to have this looked at further. It was a muted sqeaky noise.
It was there for weeks at a time.  Then would go away.  Then come back.  Seemed to come from just above the ash try or thereabout.  It did not sound like anything coming from the heater/fan.  But who knows.
It is gone now for quite awhile.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
