It's out there. Beta testers have units, I am one of these and have had a great experience with the device so far. I believe they intended on going to the production phase but covid has slowed things down.
I’ve read that DFM is more elaborate than AFM. Is it true you have to change the internals of the motor if you’re going to delete DFM? Right now range only offers AFM which is a completely different system. Just wondering.
I don't get the hate for the DFM, I personally love being able to tool around at 21mpg and have the power there when I need it. I haven't put enough miles on it to really develop a hate for it
I've only got 2,000 miles on my 2020, and to this point, it has been seamless with no issues or detectable hesitations. I work in the business, and I know GM put in a lot of effort to correct the shortcomings of AFM.  Time will tell I suppose.
What is the beef with DFM/AFM? I drive my truck and don’t notice anything. It doesn’t even tell you how many cylinders are working at any given time.
The ONLY reason I have heard that makes sense to me is it could be trouble long term.
There’s a plate with solenoids that are pressurized off of oil pressure. If the solenoids fail or there’s an issue with oil pressure, well there you go- a good way to burn off a cylinder or head..block..whatever. It’s just one more part in the system that can go wrong in a mechanical system. When this was explained to me, I can see why you’d want to disable it.
Now with regard to the aftermarket solutions to disable- is this controlled by software or is a physical mod required that voids warranty?
I emailed range and they said the RA003 will work with AFM and DFM trucks!
I’m guessing this will void the warranty, but is it possible to turn DFM back on if I needed dealer work and be ok? My truck only has 580 miles on it lol
Early AFM systems developed oil burning problems caused by the discharge oil spray in the sump on nearby cylinders clogging the oil rings.In addition there were problems with the collapsible lifters of time oil problems at 60K+ and lifters at around 100K miles. Solenoids were never the problem, in fact the LOMA manifold with its own screen clogging problems, exclusive to AFM engines also uses them for the 4 AFM cylinders. Post 1/11 AFM production has addressed these problems with modified valve cover, modified PCV system, baffle over the AFM oil discharge valve, and a new gen of collapsible lifters less prone to damage caused dirty oil. Later volume increase of 5.3l sump capacity from 6 to 8 qts has also helped to extend oil life.
Here's my .02 opinion, take it for what it is worth. Had AFMs on my 3 Avalanches and '16 Silverado and by comparison the DFM system is totally seamless. I used the Range device in my '07 Avalanche because it had the early system with valve cover, lifter, PCV and AFM discharge problems. Never used it on the later ones nor will I use one on the '19 DFM because as far as I'm concerned there is no long term data on the new DFM system, talking years not accelerated studies, on use of a defeat device vs. use without one. Got to figure it has to be pulled periodically whenever car is taken for service, State inspections, grabbing codes for the EL, etc. Dealer spots it and no more electrical warranty.
The AFM and DFM engines are designed for operation on a varying number of cylinders and the solenoids along with the collapsible lifters are designed to flex thousand of times during each drive cycle. So I'd like to know what the effects would be of keeping the oil control solenoids idle or maybe worse open under constant voltage for an extended period....heat buildup?, varnish deposits inside tappets?....and what happens to collapsible lifters that remain in the one position for very long periods when the device is removed for inspection or service and they expand/collapse and jamb with accumulated varnish buildup in a static area? And what of variability of vehicle builds and that any particular gizmo will play friendly with each and every module programming in your particular vehicle as equipped ?.
I don't know and I don't think GM knows either since a DFM engine is barely 2 years old plus was not designed for usage in that manner......but I don't have to because system works just fine as is, plenty of pep and seamless operation.......and it makes no sense to fix something that isn't broken.
  • Like 4
Just installed a catback on my 2020 and don’t really notice at cruising speeds as far as the jake brake sound. I notice it around town more but interstate it’s miles ahead of the AFM system.
Great response thanks!
Chevrolet did void our warranty because a previous owner had used the Range AFM/DFM disabler even though it is no longer on the truck they could tell. The void not only covers the drivetrain but ANYTHING on the vehicle including new parts and new work meaning if we pay them to fix a windshield wiper motor and it breaks again before we get off the lot they will NOT honor its warranty. However this is totally NOT legal and we will do our best to get this reversed but so far our warranty is VOID!! Just so you know!!
BS.  They are inviting a lawsuit.
  • 5 months later...
According to the Magnuson-Moss Warranty Act of 1975, a manufacturer can only deny warranty coverage if it can demonstrate that a non-original equipment part or related service caused a defect to occur to the original product.
Read the following link provided. A manufacturer can NOT "void" a warranty for any reason. The can only attempt to deny a warranty claim, but they bear the burden of proof.
As lapoolboy stated: they are inviting a lawsuit.
https://www.autoanything.com/resources/magnuson-moss-warranty-act-explained/
Edited by ManicFury
    B07
    B07
  • Who's Online   2 Members, 0 Anonymous, 979 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
