Hello, new here. There might be a post on this and my apologies in advance if so. I have 2019 AT4 with the 6.2l with performance pack that included the air intake system. Took my truck for it's first oil change and the dealer (where I did not buy it from) they told me they couldn't service the filter or clean it....wtf?! Any direction how I go about cleaning it would greatly be appreciated Thank you.
They don’t clean them because you have to rinse them in warm water and let them air dry. That’s just to much time for them. They’ll just try to sell you a new one most of the time. But you only need to clean it every 10k miles. Rinse in warm water, massage the filter and just let it air dry for 2-3 hours and put back on.
you could but a spare filter , if you don't have time to dry it.
From the installation manual for the intake:
Quote
Performance Air Induction Kit – Filter Service Interval
Due to the low restriction filter design, filter service life for the performance filter will differ from your owner’s manual. In order to maintain optimal air induction system performance, GM recommends the following inspection and replacement intervals for the performance air filter. Shown below are recommended intervals for distance and time, please perform service at whichever occurs first.
Distance
Time
Inspection Interval
10,000 mi (16,000 km)
12 months
Replacement Interval
20,000 mi (32,000 km)
24 months
  • 1 year later...
Do you happen to know the part number for the replacement filter.  I've looked everywhere and can't find it.
Also assuming these are non oiled filters if doing the clean and dry method?
For cleaning, are you just taking warm soapy water and then rubbing off the outside and inside and trying to "squeeze" a little while doing so?
I ordered a replacement filter for GM's Performance Air Intake from GM Parts Direct.  While I have the 5.3L, I believe the air filter element is the same one that is used on the 6.2L, but the GM Parts Direct website should be able to confirm that.  Here's the ordering information from GM Parts Direct for the filter my truck uses (as of 12 months ago):
Part Number: 84428120
Cost: $63.94
I doubt washing a dry paper filter would turn out well.  My plan is that when I approach the 20,000 mile recommended replacement mark I will closely inspect it, and use a vacuum to see if I can extend its life, and if not, put the replacement in.  Since I don't live or drive in dusty conditions, I believe I can get more miles out of mine.
Edited by Anacortes Army Guy
To my knowledge the GM performance filter isn't cleanable.  It is replacement only.  I was lucky enough to grab 2 extra filters that AMSOIL offered before they discontinued them.  Now that I have 25k on the truck, I already replaced the GM with the AMSOIL and have a spare.  Stinks that AMSOIL stopped making their air filters.  If I knew they were going to stop I would have gotten more.  They were less expensive than the GM filter.
When the time comes, I'm gong to shop around for another replacement.  If I can find one from like aFe that is less then GM then I will go that route.
Edited by Black02Silverado
  • 4 weeks later...
