Android Auto
I'm running a 19 Sierra Denali and I'm trying to get Android Auto to synch up with my radio wirelessly. But it's ain't happening. Anyone get their's to synch? If so, how?
Wireless not supported. Heard 2021 maybe.
Correct, Android Auto is only available through direct USB connection at this time as far as I know.
if your just wanting to stream music from your phone, you can connect through bluetooth and play music wirelessly but it wont use the android auto interface
Our devices will stream it fine but the sounds of it but it is the head unit (the stereo)that cannot receive it. without re programming. If it does come out in the 2021 models they can re program the 19s and 20s too.
I'm hoping a reliable universal adapter comes out at some point. Leave the adapter plugged in, and connect wireless to it when desired.
How good is GM about upgrading older models though? I have a 19, could we expect them to upgrade the headunit with new features 2 years after it came out?
I'd love for this to be true!
I just switched from a Ford. So I don't know. If they don't come out with one publicly. Maybe some tech savvy person can figure out how to be able to do it.  I know that was the case on a few secrets like getting the seat belt alarm off.
Ford did a good job with some of these things. Like the seatbelt reminder in my 07 was a sequence of clicking the belt a certain amount of times and toggling the accessory key in a certain sequence. It was even possible to do it for the drivers seat.
They also allowed users to update their headunit via USB key, AFAIK GM makes us take it to the dealership :(
Here is my experience with android auto. I connect to the stereo with blue tooth first and allow the music to start. then I connect the usb. If I do it any other way I will get 13 sec of music and it quits then I won't have phone control on the dash or on the phone to receive calls. I brought it to the dealer twice and they couldn't figure it out and even wrote the Infotainment people with no response.
  • 3 weeks later...
Craig - Were you able to figure out how to get the seat belt reminder alarm to turn off?  Was able to on my F250, but can't find a way to do it anywhere on my GMC.  I'm in and out at the ranch a ton and don't need a seat belt most of the time.  Any help is appreciated.
No I havnt found out anything. Seems like the fords were a little better towards its consumer base for options like this.
Thanks.  I'm noticing the same thing too.  I love my new HD, but missing 1) turbo boost gauge, 2) gear indicator (what gear I'm in) and 3) seat belt reminder silencing sequence.  All 3 seem so simple, but not there.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
